Question about Symphonic SC3913 13 in. Combo
Symphonic SC3919 Just got it and can't get anything but snow. The channel setup doesn't work and each channel number is pink and needs to be aqua. We try changing it and it doesn't work. How do we switch from TV to VCR or vice-versa? There is no name on the remote that came with it. There ia a button on the remote that says T-prog clear and under it it says counter reset. We are hooked up to cable.
  • itsfay Aug 28, 2008
    I want to know how to set up the channels by just using the TV. I don't have the remote
  • 4 Answers
Most likely your channels are in SAP mode, you need to set them up as stereo via the menu. Remote code should be 044. For VCR. turn TV to channel 2 or 3 then press VCR button
Posted on May 24, 2008
SOURCE:
Im having problems with my iview 780ptv cant see or hear anything just snow we try something of reset but I think we did it wrong but now it show pure snow
Snow means the TV isn't getting any signal from the channel. Try doing a channel search in the settings. Or, if you're typing in a channel, put .1 at the end of it. Like instead of going to channel 3, go to channel 3.1.
Feb 02, 2015 | Cell Phones
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Getting snow when connecting polaroid tv to dish
Hi bevybab!
I would need more information as to which TV (1 or 2) you're experiencing the problem with, but if this is a new TV it sounds like you may need to change the modulator setup.
You can find the setting under Menu -> System Setup -> Installation -> Modulator Setup. If this is TV1, change the TV 1 Out to channel 3 or 4 depending on what you have listed. If this is TV2; change the mode from air to cable or cable to air and then put the TV on the channel it shows after selecting done to save the settings.
If you can provide more information or have any other questions let me know!
Tommy Faust
DISH Internet Response Team
Nov 27, 2011 | DISH Network 322 DTV Receiver
Non-hd channels only. color is washed out with
try component cables and see if you get the same results.
Oct 24, 2009 | Panasonic Televison & Video
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
Tv has snow
First change the channel on the TV set to channel 3 or channel 4 to see if you see a menu from the Set Top Box. If so follow directions on the menu. If you don't see a menu on CH 3 or Ch 4, recheck your wiring. For more help, check the FCC website at http://www.fcc.gov/cgb/consumerfacts/setup-converterbox.html. If you are still needing help, dial the phone number listed at the bottom of the website (1-888-CALL-FCC (1-888-225-5322)) they can help and even have someone come help you make the connection at no cost to you.
Jun 16, 2009 | Insignia Digital-to-Analog Converter for...
Go video VR3845
Try unpluging the unit and the plug it back in
Apr 19, 2008 | GoVideo VR3845 DVD Recorder/VCR
Durabrand 13 inch tv
the remote need to clean pcb board ..... the chroma section pcb need to resolder loose parts such as resistor, capacitor or transistor that you may see on it.....
Feb 27, 2008 | Durabrand DWT1905 TV
No sound from my VR-507
My Kenwood1.gif VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. I tried running the speaker setup to see if it would output pink noise, I could hear the test sound, but I couldn't hear any audio from the TV or DVD player..
Help. :-(
Dec 14, 2007 | Kenwood VR-507 Receiver
Televison & Video Logo
235 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
