Question about D-Link DI 514 Wireless Router (DI-514)
My accer laptop looses its wireless connection at my home every 1 to 1.5 hrs.It works fine every where else.Could this be my dlink?
  • D-Link Master
  • 4,338 Answers
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the D-Link router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: D-Link suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the D-Link router may cause conflict with other D-Link routers within your network range. D-Link suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
D-Link IP address : 192.168.0.1
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 13, 2009
I have a dlink n150 router dir-600L. i tried to configured it and changed the SSID and network key. the problem is, i cannot connect it to the wireless connection even though the network appears on my
Did you enter the security key (password)? It may be your laptop? Try resetting the D-Link to default settings and connecting to the laptop. They reconfigure the SSID and Security Key. Write down the info for future use. Here's a user Manual: http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-600-wireless-n-150-home-router
Jan 24, 2013 | D-Link DIR601 WirelessN 150 Home Router...
Using a router as a wireless repeater/bridge
Try out this lifehacker artical. I am copying the link to my evernote, so I can try it at home.
http://lifehacker.com/5563196/turn-your-old-router-into-a-range+boosting-wi+fi-repeater
Feb 28, 2012 | Computers & Internet
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
Windows 7 Wireless connection problem
Disable IPv6 from your Laptop & then check ur Wireless Connection...
Also let me know the status...
Nov 12, 2009 | Microsoft Windows Vista Home Premium with...
I bought recently a lenovo laptop (G450) loaded with windows 7. I have wireless internet in my home that I use with my other windows xp laptop and it works fine. I never ever been able to connect to the...
have the same problem.  even after assigning a valid address statically to the network card and connecting with a wired connection, i cant even ping the router
Nov 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cannot connect via wireless to dlink 655. wired connection works fine. when i disconnect to go wireless the laptop sees the dlink but there is no internet connection. running Vista Home Premium. static...
You must manually configure the wireless settings. Go to Network and Sharing Center > Manage Wireless Networks. Remove all the listed network there. Then click Add > Add Network in Range > Select your signal > Type the security if you have and press connect. That should do it.
Sep 23, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Lost Wireless Connection DLink G604t
So if your other 2 laptops (WinVista) is working then that means that the wireless on your Dlink is working fine. Its possible that its a problem with the settings on the winxp laptop. does your winxp laptop have a builtin wireless adpater? What does it say on your winxp laptop is you will try to view the available wireless network?
Jul 29, 2008 | D-Link DSL-G604T Wireless Router
Network router printing issue
sure..you can put all the computers on the same workgroup, and form a network
we got fresh wireless drivers here too
Mar 17, 2008 | D-Link Wireless
Wireless connect
Call your ISP and demand a DSL tech visit. It sounds like either you do not have the correct password in your gateway to allow for access OR you have your computers wireless connection trned off. On my dell, i use Intel pro wireless set to connect. Your ISP's csr support should be able to get this up and running for you.
Mar 14, 2008 | Westell Wirespeed VersaLink...
D-Link DI 514 Wireless Router (DI-514) Logo
134 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
