Question about Garden
Hooked battery up wrong when jump starting lawn tractor
I hooked the the battery i was trying to jump start pos. to neg. and now the mower will not even turn over or nothing with a new battery. what do u think i burnt up.
    Genius:
  • 1,055 Answers
There a fuse in the power wire you probly blew it!!
its in the wire coming from the + side of the battery too the switch then too the starter!!
Posted on Apr 13, 2009
How do I jump my craftsman 3500
same way as you jump anything pos to pos neg to ground .
Jul 22, 2016 | Craftsman Garden
How do you give a jump start to someone using a 2007 Dodge Charger?
The underhood connections can work by themselves...POS to POS, and NEG to NEG...sometimes dirty/weak connections do not allow the power to transfer fully from the underhood connections...if this is the case then you need to connect directly to the battery in trunk for full power charge...again POS to POS, and NEG to NEG...hope this helps
Jun 09, 2015 | 2007 Dodge Charger SE
How do I hook a 6 Volt Battery up on Farmall Cub Tractor
look for positve on battery a + sighn is what you are looking for on battery then find positive battery cable in tractor no witch it between pos cable neg cable hook neg to battery fist to battery then hook up positve cable ready to start
Sep 02, 2014 | Garden
Mmimum wiring diagram to needed to start engine. no wires on mower, no key switch. i just want to hot wire the motor to see if it runs.
if jumping with a battery and cables
pos on starter post and neg to side or bottom of starter or close by
you will need to run a pos wire to gray wire to the bottom of the carb, when it starts leave pos wire on carb disconect pos to starter
Oct 06, 2013 | Parks Optical 13.5hp Briggs And Stratton...
New battery installed properly 2 weeks ago and today when trying to start the mower, the battery blew-up.
short circuit between pos and neg somewhere. Positive wire touching ground somewhere. Pos wire rubbed against metal.
Sep 01, 2013 | Ferris Garden
Huskee LT 4200 Lawn Tractor I had to jump my mower today and mowed for 45 minutes, turned it off, added gas, started mowing again for 30 minutes, turned it off and now it won't start, turn over or...
A couple of possibilities, either the main fuse has blown, they are normally an auto motive design and located undrt the the hood of the machine, or the start solinoid has burnt out.
Jun 18, 2013 | Garden
John deer mower
Possibly just the fuse. But if you say the jumpers WERE positive to positive and neg to neg it shouldnt have been a problem but maybe the pos clamp touched the body. That would have cooked the battery. First check the fuse, if thats ok then connect your neg jumper lead to the chassis of mower to neg of truck and the pos to pos of truck and hold the other end to the large terminal on starter motor.This will bypass everything and only test starter. Engine will spin over if starter motor ok. There will be a strong spark when touching terminal so watch for fire hazard.
Jan 30, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Can I jump start a john deere?
Yes... just make sure that you have the battery voltages the same and that the Pos. and Neg. are lined up correctly...
heatman101
Aug 13, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Will not start fuse ok battery ok they said try new starter, its ok turn key on hear click Sound sounds llik up at carberator, AMP gauge gos negetive and starter will not ingage, belt for mower is...
I would try to jump the starter. Pos cable on the starter then ground out the neg, it the starter turns over that isnt it. then check the smaller wire going to your soleniod, when you turn your key to the start position it should have power. then check to see if there is power from the battery to your soleniod then with the key turned power from the soleniod to the starter.
Aug 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
525 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
