Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I was able to get the disposal off, however can't
I was able to get the disposal (an in-sink-erator) off, however can't pry the mounting plate off of the flange-help
  • 1 more comment
  • hoff13s Apr 13, 2009
    thanks, my problem is there is no indentation or other variation in either the flange or the ring to allow me leeway-so all the prying has been to no avail; there doesn't seem to be a way to get the ring off the flange! logically I know there has to be a way.. and actually mine is an older model- a badger 1 if that matters
    Thanks so much- the actual snap ring had not been visible and the screw driver hadn't found it; but your clues and the diagram (much better than the one with the new unit) solved the problem. the old unit is now removed!
    Now to make sense of the new one. it's a Waste King legend series 9980 and based on what we learned removing the old i think installation will go alright once i get past one small thing- which is removing the flange, etc from the unit in the 1st place. if you have any clues on that would be great.
    also wondering-how important is it to use the plumber's putter around the flange base? the guy at OSH said it didn't matter and he usually installed without that.
    Well, this project is going to be finished tomorrow; but i believe what you've provided will be very helpful. you are my hero for the day, thanks so much!
  • 8,197 Answers
Undo the 3 screews and lift flange. then you will see a snap ring in grove remove ring then flange will come off. Will try to get you a manual to show you.
Posted on Apr 13, 2009
  • 4 more comments
  • Jyackle5
    Jyackle5 Apr 13, 2009
    Go to this link on page 4 it will tell you how to remove.
    http://www.insinkerator.com/pdfs/US_ICU1...
  • Jyackle5
    That manual is for a bager 1 also. If you remove the screws then you can rotate the whole thing till you see a split in the ring pry from one side of the split from there. Also I know that the flange can get stuck on the ring at some times you just need to work it free. It will take some muscle. Also make sure the is no plumbers putty that fell to flange and got hard that will make it hard to remove also.
  • Jyackle5
    Also with all screws removed stick hand in hole and squeeze the to parts together as if holding to down on sink and pushing flange to bottom of sink.
  • Jyackle5
    Ok to remove flange from new wast king you twist the metel with a notch in it a 1/4 turn counter clock wise if you look real good you will see how it comes off. As for the plumbers putty you do need it or you will get a leak between the sink and the disposal and you will have to start over. I will try to find manual so you can see. Do not see the 9000 model though just 8000
  • Jyackle5
    Ok go here and scrool down to the movie thing and click on the easy movie install. It will help you install. Please rate me as FixYa! down below with the 4 dimands please.
    http://www.waveplumbing.com/store/index....
  • Jyackle5
    Go straight to step 5 on link above
The reset button is pushed up insie the bottom plate
1) Probably replace disposal, unless unit is still under warranty.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
2) Add comment and say what you discover
Feb 01, 2013 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Leak from area where cord comes out of the in sink erator
Not good seal could be bad are you sure it is not leaking from the top and running down the side.Fill sink all the way then pull plug get a flashlight and examine well.
Apr 17, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I have a Pro 17 Inksink cover control erator garbage disposal that is not working. Will a Inksinkerator cover control evolution fit good in the same place?
Hi, Yes, that will work...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Sep 19, 2010 | Now Evolution In-Sink-Erator COVER CONTROL...
My badger 5 plus in sink erator is not working
Here is a tip the I wrote that may help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammedheatman101
Sep 04, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
How do you remove the bottom plate to replace the switch?
There is a screw or a nut that you need to turn counter clock wise to remove and loosen.
May 01, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
How do I change the rubber baffle that prevents
You need to remove it from under the sink and insert a new. Then reinstall. Not a real hard job if you are handy.
Kurt
Mar 17, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Badger 5 EX 3/4 Hp In sink Erator
the disposal is attache to the button of th sink by means of ring and clamps.
take a look how th ekitchen sink is mounted. the disposal is mounted the same way. you may need to get new rubber seal and a new plate for the buttom, where the screws is. you can take the ring to the near home center of plumbing store, and get a replacement.
you can use "plumber's putty", or " goop" .thing else will keep the water out.
Nov 05, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
536 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
