2000 Plymouth Voyager Logo
Posted on Apr 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Van is turning over but acting like it's nt getting fuel
My van sat on empty for over 2 months and recently got it fixed and running. The other day it acted like it was out of gas so I filled the tank and it ran fine all day. I parked it for 2 days and now it won't start again. It still has almost 7/8 of a tank of gas.
Anonymous
Level 2:
  • Expert 116 Answers
  • Posted on Apr 13, 2009
Anonymous
Expert
Level 2:
Answers
116
Questions
0
Helped
61133
Points
459
Your fuel pump has died on you
1helpful
1999 GMC Savana starting problem: Engine turns over, starts, then shuts off after 2 seconds. Fuel pressure is good 60 psi. Treated fuel with StaBil and Berryman's B12. Suggestions?
Anti-theft problem ? Computer disables fuel injectors after a couple of seconds ,that's what it sounds like . Does it have a SECURITY light on ?
How do i revtieve the trouble codes for a 2002 chevy astro van
loosen fuel lines at throttle body when turning key to on possion , careful not to spill gas all over engine, do you hear fuel pump running and try to put at least 4-5 gallions of fuel, you could try a (LITTLE ) shot of starting fluid ?good luck hope this helps.
99 Astro Van random misfires P300
Before you replace the injectors have them do an injector balance test. Normally wet weather does not effect fuel system. Sounds more like you have a crank or cam sensor acting up.
I HAVE A 1986 GMC VANDURA 3500 CARGO VAN,ALWAYS TURNS ON WITH NO PROBLEM,OK HERES THE THING.MY GAS METER WENT OUT RECENTLY SO I DROVE IT AROUND ALL WEEK BASICLY JUST TRYING TO EMPTY THE TANK SO I CAN FILL...
If the fuel level is very low and the van is not level it's not going to start even if the pump is good.
When you turn the key to on you should hear a fuel pump noise for 2 to 3 seconds if the key has been off for at least 10 seconds,and when cranking or the engine is running the pump runs because there's oil pressure sending power to the pump.
Have someone listen back at the tank.No Noise?then it might be time for a fuel pump.
Your fuel filter may be just ahead of the rear axle on the passenger side under the van.
But.....if your gas gauge went out and now your pump quit,maybe the wiring back at the tank is corroded?
1helpful
2answers
2001 express van fuel guage doesnt work
SOUND LIKE FUEL GAUGE IS FAULTY.IF YOU REPLACED FUEL PUMP ASSEMBLY WITH NEW FUEL LEVEL SENDING UNIT.PROBLEM IS IN THE GAUGES.
04 Pontian Montana DVD, dead battery
sound like a fault in dvd player.its running battery down.have dealership check it out.sound like a electrical problem.
My Plymouth Voyager (1999) stop on me, and When I
Sounds like one or more of your fuel injectors is stuck open and dumping raw gas into the exhaust system. I would replace all the injectors since there was sugar run through it.
1helpful
Ram van dies
sounds to me like the fuel pump is bad, when it warms up it dies, try to check this by filling the tank and running a while, then run the van with a near empty tank and see how it does. A full tank of gas should keep the fuel pump cool as it is surrounded by the liquid. I had a similar problem. when my tank got to about a quarter full (3/4 empty) the van would shut off after a short distance, then after sitting for a while would start up again get me a little farther then shut off again. i ended up changiung the fuel pump cost me almost $300. if this simple test shows no results the you got electrical problems, check distributor, and surrounding cables. good luck. also check your fuses could be dirty!
Top Plymouth Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Plymouth Expert? Answer questions, earn points and help others
