Question about Canon imageCLASS D880 All-In-One Laser Printer
Blank Pages just like His!!!
My situation is about the same as the guy before me. I had a paper jam yesterday, followed the instructions, took out the cartridge and replaced it. Today my pages are blank. I've replaced my cartridge and put an old one in and its still not working. I've looked at all my wires and made sure everything was working. Its still printing blank pages. Please help!!!
  • vakge Apr 04, 2009
    how do you do factory reset on canon d880?
    Problem Solver:
  • 10 Answers
Posted on Nov 06, 2007
Why does my printer produce a paper jam when printing from laptop but does not jam when copying
When you order a print from the laptop, it gets the paper from the paper tray. When you copy, the paper has a slightly different path it follows to deliver your printed result. Try to put the document in the tray with the blank pages and see if it also jams! Let me know what you find out!!
Sep 28, 2014 | Office Equipment & Supplies
Reading no paper paper tray is full
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Pager jam after 5 pages
clean the tunner or change the roller
Feb 05, 2010 | HP LaserJet 2300dn Printer
Printer is printing blank pages
Printhead may need to be ran through a few cleaning cycles and or there may still be some small pieces of paper still in the path of printhead.
Check this and let me know.
Feb 11, 2009 | Brother Multi-Function Center MFC-240C...
Two error messages persist after replacing toner cartridge.
This kind of error indicates that your toner is not properly set or there is some paper jam. so please follow the instruction and open the panel and remove the toner and check for any kind of paper piece and than refit toner properly and close the panel and than check you will definatly able to resolve the problem ok
Dec 20, 2008 | Canon imageCLASS MF4270 All-In-One Laser...
Extra pages after paper jam
that's from a problem with the print queue manager..empty it out, power down completely, start again..
Aug 08, 2008 | HP Inkjet 1200dn Printer
Paper comes out with nothing on it
On the new cartridge, did you remember to remove the plastic seal from the toner? Do you get blank sheets only when you print or when you make copies too? Were you careful when clearing the paper jam or could you have accidentally damaged the printer?
Jan 07, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Blank pages printing on ImageClass D680
Greeting IceCreamMan, It sounds like you?ve eliminated the toner cartridge as the culprit. I suspect that when you did the disassembly and connector was missed or an electrical connection fault developed. Look for the electrical contacts that connect to the toner cartridge, they may not be making contact. Make sure the spring contacts on the printer are connecting to the cartridge and that they are clean. If that?s not it then check: -all connectors to make sure they are plugged in and oriented correctly -for missing or incorrectly aligned top or side panels (sometimes they are linked to switches) -all wires (for damage) and secure connections Let us know how it goes and don?t forget to rate the posting.
Jan 04, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon imageCLASS D880 All-In-One Laser Printer Logo
296 people viewed this question
old marine
old marine
