Question about Samsung Digimax S600 Digital Camera
Samsung digimax D73 not turning on
The camera turns on for about 5 seconds then bleeps three times and turns itself off, i've tried changing the batteries and charging the samsung ones so i know it's not that. if anyone could help please do, i'm going to university in a week and really want it fixed for that!!
  • 10 more comments
  • Anonymous Nov 04, 2007
    I have the same problem.
    Also, when it turns on, the batteries are empty within 5 minutes!
    WTF is this? Samsung doesnt even know this model, on their site there is nothing about the D73!
  • lms003 Dec 12, 2007
    I too have the same problem and know of a frined who also has the same camera ... the only way I fixed it last time was to take it into a camera shop and they said to plug it into the PC for a while and switch it on .... this worked for another 6 months and now I cannot even get it on with brand new batteries for the PC to even recognise it! I am going to complain to Samsung online please join me as this is a nightmare ... I am on my holidays with the best sites in Australia and no photographs!!
  • Anonymous Feb 24, 2008
    same problem samsung have no idea must need some sort of reset also the batteries you have to use are limited and life span very poor mines out of warranty so it looks i have to take to a camera shop more expense
  • Anonymous May 28, 2008
    Also have a D73 its useless worst buy ever Batteries die instantly, even 2500 rechareables. Trying to strip camera at present!!
    Stew
  • Anonymous Oct 04, 2008
    I have the same problem, replaced with new batteries will show low battery in view screen then beep 3 times and turn off, any one know how to fix this, I also tried a new memory card no help...
  • conmla Oct 13, 2008
    I have the same problem but it sounds like there are no solutions... correct? When I turn it on it beeps 3x and then turns off.
  • Anonymous Oct 24, 2008
    fitted new batteries, press power switch green light lit beeps three times, but doesn't turn on
  • missbecky Nov 14, 2008
    i have a very similar problem too, i my low battery screen doesn't come up, but it tries to start up and turns off almost straight away..... i've tried new batteries and different batteries and they've not worked. The lens doesn't come out either where it used to when it turned on.
  • APPLEJACKS34 Nov 25, 2008
    I HAVE THE SAME PROBLEM, TURN IT ON AND I HEAR 3 BEEPS AND THEN IT TURNS ITSELF OFF. WHAT THE HELL IS GOIN ON?????
  • bhrinfo Dec 15, 2008
    Well i think we have the same problem we've put lots of new batteries in and we must have more luck than most because at least we get to press the shutter button before it dies Oh by the way this is a replacement camera our first one did the same and went back to Makro
  • Anonymous Dec 19, 2008
    12/19/08 I have the same problem. I use alkaline batteries and put fresh ones in but it still does the same thing.
  • Anonymous Dec 21, 2008
    samsung d73 - i have the same problem, i have always used rechargable batteries untill they died, then just tried ordinary batteries, from then on the camera turns on, bleeps three times and turns off. can anyone help?
I had the same problem, but it appeared, when my rechargeable batteries died.. it just friezed  while the lens was coming out. it came out abaout a half of it's length.. tried connecting to pc, different batteries, until pressed the lens a bit towards camera and then tried to pull it out a bit - and it came back again. It started to work. So I gues all of your problems has something to do with the lens.
Posted on Jan 19, 2009
    New Friend:
Had a very similar problem, the camera beeped three times but no lens action at all. what i did was sparingly applied wd40 useing a q tip all around the lens circles with the camera lens face up and left it for ten minutes for the wd40 to penatrate, then here comes the tricky. part turned the camera lens down and as i turned it on i tapped the corner of the camera on to the edge of the table useing my mouse mat as a cushionand hepresto out came the lens and the camera turned on i cleaned allround the lens and all was ok good luck with yours
Posted on Jul 03, 2011
Try using alkaline batteries.. shop bought batteries such as morrison's own are generally very poor
Posted on Oct 12, 2008
I have the same problem; but it happened right after I accidentally used non-rechargable batteries after charging them. I'm looking for a way to reset the camera and see if this works, I also have no computer cable.
Posted on May 20, 2008
SOURCE:
My Samsung ES63 camera won't turn on even though it's fully charged. It makes a weird bleep instead.
did the camera sustain any drops or water damage?
if not then i would recommend to take it back to the manufacturer and request a refound for the defective equipment.
Jan 31, 2012 | Samsung DigiMax Cameras
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
My Samsung Digimax S800 Camera, when push power bottom, the camera green lite near power button and camera bleeps twice. Then turn off. Zoom len is fully extended. Chnage Battery three times.
this problem is a is usual occurrence when the camera is not well powered.
ie. the battery might not have enough charge on it or might have gone bad and require you to replacei it.
please ensure you get the battery with right voltage and wattage, the required is usually written around or in the battery compartment.
Jan 14, 2011 | Samsung Digimax S800 Digital Camera
Samsung pl50 camera - lense wont go back in and wont turn on
The problem with mine was that the lens motor was somehow stuck. I gently pulled the lens out as I turned the camera on. It went back to normal afterward. Hope this helps
Feb 01, 2010 | Samsung PL 70 SL720 Digital Camera
Camera turns itself off
or this problem try the following:
* Try removing the memory card and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 SAMSUNG
Hope this will help
Thanks
Byron
Sep 25, 2009 | Samsung NV3 Digital Camera
Put new batteries in, camera bleeps three times & switches off
hi meeshfriel,
The battery might be damaged. try recharged the battery at least 2 hours maximum of 4 hours. If the problem persist it is your battery needs to be replaced......
Thanks.
jonags
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Samsung L200, you turn on and after 5 seconds you hear 3 beeps and its turned off automatically
Hi Bruno,
[ENGLISH]
first, try to reset the camera to factory defauts. Your memory card maybe corrupted as well, try to format it on the other camera. Another issue is when lens get stuck. Check if the lens go in and out of the camera smoothly. Good luck!
[BRAZILIAN PORTUGUESE]
Olá Bruno, como você parece ser brasileiro como eu, vamos em português também. Tenta resetar a câmera e formatar o cartão de memória. Vê se as lentes não estão emperradas e se elas entram e saem da câmera de forma bem suave. Boa sorte!
Oct 04, 2008 | Samsung L200 Digital Camera
Wont charge and makes noises
First get rubbing alcohol (higher % the better) and brush both ports on the phone and the charger. Blow dry it for a minute or so and plug in.
If still no-go, then try it with another charger....if the same result, the phone has a bad charging port and need to be replaced.
The newer phones are coming out with very sensitive ports, so you have to be finesse with them.
Apr 15, 2008 | Samsung SCH-u740 Cellular Phone
Won't stay turned on!
IF YOU GO IN TO YOUR CAMERAS MENU AND OPTIONS YOU WILL FIND A SETTING FOR THAT. EITHER UNDER POWER SAVER OR MAIN CAMERA OPTIONS AND SETTINGS. I HAD TO CHANGE MY DELAY TIME TO MAX. ALL CAMERAS NOW HAVE A TIME DELAY BEFORE POWERING OFF TO SAVE YOUR BATTERIES. ITS A GOOD IDEA IF YOU ACCIDENTLY SET YOUR CAMERA DOWN AND FORGET. BUT IT IS A PAIN WHEN IT COMES SET FOR 5 SECONDS. HOPE THATS ALL IT IS
Sep 27, 2007 | Samsung Digimax S630 Digital Camera
Samsung Digimax S600 Digital Camera Logo
445 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
