Question about Kodak EasyShare M853 Digital Camera
Every time I turn my camera on, it shuts itself off immediantly
I have a kodak M1063 and one day i went to turn it on, the lights came on and it made the sound like it was turning on, but then the screen goes black, the lens goes back in, and it shuts off. The battery is fully charged and running fine. A friend of mine thinks the on/off button could be jammed but i have no clue how to un-jam it! HELP!!
  • 2 more comments
  • xniki619x Apr 25, 2009
    omg i have the same exact problem! WE NEED AN ANSWER!!! SOMEONE HELP US!
  • Anonymous Apr 27, 2009
    I too have the exact same problem and I've only had this camera for a few months.
  • Anonymous May 21, 2009
    oh my gosh i just got it and i dropped it nd i have that problem I REALLY need it for my brothers graduation PLEASE HELPPP!!
  • ggbjb May 22, 2009
    i have the norcent digital camera why does it turn on then does the beep beep sound then shuts off?
    Master:
  • Kodak Master
  • 304 Answers
Hello!
Please check the "Troubleshooting" part of the manual.
https://manualsbrain.com/en/manuals/1041783/?page=51
I hope it will help!
Posted on Oct 27, 2017
SOURCE:
  • 1645 Answers
SOURCE: Won't turn on after charging; lens just sticks out
Charge it again with a new batery and the 5 volt charger.
3 hours.
Vitally
Posted on May 15, 2009
SOURCE: my kodak easy share M1063 turns on then shuts right off how do i
I had the same exact problem. When the camera turns on and then lens extends, hold the lens out while the camera shuts off. Then sort of move it around a bit. I did this and when I turned it on, it was fixed. I guess something was jammed in the lens.
Posted on Jul 07, 2009
SOURCE: My battery is fully charged, camera goes on and shuts off.
this generally happens if you have dropped it. when the message comes. try tapping the camera. if it works then you are lucky. if not then you have to change the lens array. it costs about 60$
Posted on Jul 15, 2009
I had the same problem; I blew in the lens as it extended and everything's working now. Seems to be VERY sensitive to dust in the lens/zoom mechanism.
Posted on Jul 23, 2009
  • 8 Answers
SOURCE: My Kodak Easyshare M1063 won't turn on
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem and this fixed it, it seems to be a common problem.
Posted on Aug 15, 2009
My Kodak M1063 digital camera will not turn on no power at all
Kodak EASYSHARE M1063 Digital Camera My Kodak M1063 digital camera will... Answer my camera will not turn on no power at all.
Feb 13, 2010 | Kodak EASYSHARE M1063 Digital Camera
Easyshare M1063 Digital Camera We received as Christmas present. Went to use it and it shuts off as soon as we turn it on.
This is normally a sign of weak/worn out batteries, and it's not uncommon for a camera to come with bad batteries. Make sure that your batteries are fresh/fully charged (HINT: you might try them in another device to make sure that they're good) and that your charger is working properly. Corrosion shouldn't be a problem on a new camera, but check the battery contacts inside the camera to make sure that they're clean. If you still can't get the camera working I suggest that you contact Kodak customer service via the Kodak.com web site or return the camera to the point of purchase.
BillB
Jan 21, 2010 | Kodak EASYSHARE M1063 Digital Camera
Hello.i charged my kodak m1063 easyshare last wk bec it turn off by itself bt i noticed that d light not working.when i went to the kodak booth on the mall and they use their m1063 charger it works in my...
Your charger is covered under the same warranty as your camera.
If your charger is faulty you can have it replaced free of charge if the camera is still covered under the warranty.
In order to organise your replacement please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Please note you must have your serial number and camera model ready when reporting the fault. Depending on the serial number the agent might ask for a proof of purchace.
Jan 04, 2010 | Kodak EASYSHARE M1063 Digital Camera
New camera show me how to set date/time
Usually this happens when the battery is not fully charged. Please check your battery.
luciana44
Aug 24, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera will not stay on
I have basically the same problem. I sent it in for repairs. It came back and I followed the instructions they came be. BUT IT STILL WONT WORK. it's worse then before, the logo wont even come anymore ! :(
Jul 18, 2009 | Kodak EASYSHARE M1063 Digital Camera
My kodak M1063 will turn on but as soon as it does it turns back off. i have charged it and there is still no change... help me please
It is telling itself that it has a problem. When turned on a camera goes through a series of test, if one fails it shuts off. You will have to have the problem diagnosed or as is most often the case today is repairs are more than the camera used value.
Jul 03, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera won't stay turned on
Format the SD memory card.
Get the 5 volt charger and charge 3 hours.
Format the internal memory.
Menu button and change to power save.
Do not use the flash all the time.
Vitally
Apr 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak EasyShare M853 Digital Camera Logo
106 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
