Question about Epson Stylus C86 InkJet Printer
General Error My printer keeps giving me a 'general error' message. I have turned it on/off. It has full ink cartridges. I won't print anything. Does anyone have any idea what is wrong with it?
  • Epson Master
  • 705 Answers
Sounds like you have hit the Ink Overflow Protection Counter. This is a counter within the firmware that monitors how much ink has been pumped to the waste ink pads in the base of the machine. When it gets to a certain figure the machine stops until the counter is reset. Get in touch with the people at http://www.TheServiceManualShop.com and ask about their rescue kits for this machine. If they do not list one on the web site they will make one for you.
Posted on Sep 12, 2007
Why can't I scan, print or do anything? There is no error code.
Patti, you may have to do a hard reset.
1) Disconnect the USB cable from your computer
2) Remove the ink cartridges
3) Unplug the power cord. Wait for a couple minutes. Plug the unit back in,hit power button if needed.
4) Wait for the "Insert Cartridges" message, reinstall the cartridges
5) Close printers doors
6) If you get a recalibration message, allow the printer to complete this task
7) Reconnect printer to USB cable
8) Try your printing again.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Re How to perform Hard Reset
hp officejet 6500 error general printer error
HP Multifunction Printer Resets HP Officejet 6500
General Printer error with no alphanumerical code in Mac Control panel for...
Mar 31, 2016 | General Office Equipment & Supplies
General Error message on a Epson Stylus NX100
Incase you have used a compatible cartridge , they may not work at times . Insert the old cartridge and check , if it prints ( even though partially ) . The problem could bein the cartrige or the fitting of the same .
Dec 20, 2012 | Epson Stylus NX100 Multifunction Printer...
Epson general error
Sorry to disagree but a "General error" is rarely anything to do with the waste ink counter and more likely an issue with any number of other parts.
If the waste ink counter were at fault the message would include keywords like "Service required" whereas "General error" is just a generic catch all term for "It's far too technical for us to explain it to you so we won't".
All of that aside, the "General error" can still result from a waste counter reset, particularly when the cartridges in the printer do not have sufficient ink in them to allow a priming routine to complete. The printer assumes that a reset will be done with fresh cartridges (and originals at that) so if the cartridges are low it can bomb out with a general error because it knows it can't complete.
There are a slew of additional "General error" troubleshooting pointers on this article which I keep updated whenever I discover a new quirk to the whole thing:
http://www.octoink.co.uk/kb/questions/128/
Hope that helps.
Aug 14, 2012 | Epson STYLUS R230 InkJet Photo Printer
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
The sgreen says general error, see your printer documentation for information about clearing the error.......of course I can't find the manual
Everything you need; manuals, drivers and interactive guide can be found here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=26322&infoType=Overview
Below are two possible soultions for a General Error:
1. When a General error message appears in the display on your printer's control panel, the print head may not be able to move because of some obstruction. Follow these steps:
  1. Turn the printer off.
  2. Open the printer's cover.
  3. Gently remove any jammed paper or other obstructions from the paper path.
  4. Close the cover and turn the printer back on.
alert_note.gif Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the printer.
2. When a General error message appears in the display on your printer's control panel, the print head may not be able to move back and forth freely.
If your printer's ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps:
Turn off the printer.
  1. Open the printer's cover.
  2. Press the ink cartridge cover to make sure it is completely closed.
  3. Close the cover and turn the printer back on.
Before considering other options you might to try unplugging the printer from the power supply; give it 5 - 10 minutes before plugging back in and restarting.
Hopefully this will help resolve the problem. :)
Dec 09, 2010 | Epson Stylus Photo R300 InkJet Printer
Will not print. e 2 flashes on screen
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
You can gave it a good clean out try.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 13, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber
actually ink absorber is full means you printer inside got small pieces towel
to absorb ink. but Canon PIXMA printers display an error when a certain internal counter suggests that the ink absorber may be full. If you've done a lot of printing, the ink absorber may actually be full and you might need to have it cleaned or replaced to ensure the best printing quality. However, if you haven't printed that much or you have and you just need to print something right this minute, there is a way to reset the counter and stop the error from showing up again
please try go to this website :
http://ij-forum.blogspot.com/2008/09/how-to-reset-ink-level-of-fine.html
the you go left hand side download General Tools (EEPROM Resetter) Collection and install on you cpu.
after download remember to turn on printer before install it.then go to Reset ink counter by clicking Reset main on waste ink counter menu
try this if can't i think you need send to shop for technician to open it and clearning for you....
Aug 17, 2009 | Canon PIXMA iP1600 Printer
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
Epson stylus R 310 "general error" message
Those generic refills are not worth i, plus they may void the warranty. Try removing them and cleaning the little circuit board sensor. Make sure leaked ink hasnt covered them.
Oct 22, 2007 | Epson Stylus 1000 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
193 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
