No Power in Mitsubishi VS-55705
Hi!! There's something wrong with my big screen tv. After a few weeks without using it ( i was abroad), everytime a press the power button a small green lcd bulb turns on (as normal)as if the tv is turning on as it should, but one second later it turns off again. This happens in no time for the screen to turn on. All i hear is a "click on" sound and later, a "click off" sound. This happens every time i press the power button. Could this be the capacitors? What solutions do you recommend me? Thanks in advance... John
  • 1 more comment
  • john3jo Sep 11, 2007
    Hi Again!! And thanks for the amazingly fast answer.
    I ran the Self-diagnosis feature, and it gave me a 2-3 set of blinks (Deflection protect: loss of vertical or horizontal deflection, according to your mail).
    So, now that we know what the problem is, i have a few questions...
    Since i have a little soldering experience, could this be solved by my own hands?. If this is possible, what do i need to change or do?
    And finally, if the solution is too complicated in order for me to get trained tech to do the repair, how expensive is usually this problem?
    Thanks for your support!..
    John
  • lisalem Nov 13, 2007
    I have the same problem with my Mitsubishi WS-48315 - no power. I pressed the input and menu buttons simultaneously and got the 2 - 2 set of blinks. According to your post, this = short protect. What does this mean? Is there something I can do to fix it, or do I have a serious problem? (With the TV, I mean. :-))
  • citypaul1 Dec 01, 2008
    Have model VS-50705. Light flashes 3x. pressed menu and input at same time code 12 came up, would appreciate any suggestions?
    thanks,
    citypaul1
    Genius:
  • 1,153 Answers
Hi John This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Posted on Sep 11, 2007
  • Lashawn Robinson Sep 11, 2007
    If you are good at soldering and changing out parts, you can try it but be carefull not to damage anything else and do not solder bridge(waste solder across any part, because this may lead to set not working)MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Try this first.
  • Lashawn Robinson Sep 14, 2007
    You could call PTS-18008447871 and compare a board Deflection, to tech coming and repairing.
My 48315 just quit while I was watching it. I let it set off for about 15 mins. and tried it again and it came back on.
Posted on Jul 18, 2010
SOURCE:
Mitsubishi VS-55705 error code 12
"12" is no error, no problem. Also, if you unplug TV power, you lose all errors in memory.
Apr 26, 2014 | Mitsubishi VS-55705 55" Rear Projection...
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Jun 07, 2008 | Mitsubishi VS-60607 TV
S.O.S anyone out there
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Thompson rear projection tv 44" Misty picture
Remove cardboard back ... clean RGB lens caps with soft cloth
That's it ! Should be nice improvement......T.
Nov 28, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi Big Screen TV VS 5043
depending on the model it could be serveral things. it could be convergence ic's gone bad or a problem with the power supply, something is shuting it down . contact mitsubishi for your nearest sevicer
Oct 19, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Black horizontal lines appear after tv is on for 30 minutes
Kellia,
I had the same problem with our VS-55705 Mitsubishi. It seemed to me that this was a problem of heat.
I unplugged the TV and then took the cover off of the back of the it. I then used canned air to blow off the collection of dust from the components. Then I vacuumed as close to everything as I could without touching any of the components. I then used glass cleaner to clean up the surface of the three bulbs.
I plugged in the TV and it has worked perfect ever since. I haven't put the rear cover back on it yet. That could have been all that I needed to do to fix it. I'm too busy enjoying a nice picture to try putting it back on. Cleaning the bulbs really helped the quality of the picture.
Good Luck!
Oct 11, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Television
Sounds like its going into auto protect shutdown. Try holding the imputand menu bottons in together for 5 seconds and see if the green light blinks out a series of blinks. If so notice what they are, should be a 2 digit code if its going into shut down. If not its a power supply issue. Also you can look the boards over for evidence of CRT fluid leaking on the boards, I have seen this happen alot to the VS models it causes corrosion of the components and you will experience no start up condition like the one your describing.
Oct 04, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Televison & Video Logo
973 people viewed this question
Top Televison & Video Experts
Ekse
