Question about Canon PIXMA MP830 All-In-One InkJet Printer
USB001 I JUST TOOK A NEW POSITION, NEW OFFICE. THE PERSON BEFORE ME WAS NEVER ABLE TO USE THIS CANON MP830 PRINTER/SCANNER/FAX MACHINE. I ATTEMPT TO PRINT (BLK/WHITE AND/OR COLOR) AND ALWAYS GET THE USB001 ERROR MESSAGE: MORE THAN ONE INK TANK OF BLACK AND YELLOW INSTALLED. I HAVE REPLACED THEM, I HAVE REMOVED THEM, SHOOK THEM, YOU NAME IT. IN THE SIX MOS IN THIS POSITION, I HAVE BEEN ABLE TO USE THIS COPIER ONCE. CAN YOU HELP ME? I HAVE MADE THE FOUR SQUARES, COLORED THEM VARIOUS COLORS AND ATTEMPTED TO PRINT TO SEE IF THE PRINTERHEAD WAS WORKING- IT WON'T PRINT AT ALL.....
  • 3 Answers
Aligning the cartridge has nothing to do with the problem of the u150 error that two of the same ink tank cartridges are installed. It's a defective chip in the ink cartridge, as soon as I placed a new cartridge in it worked like a charm. HOLD ON TO YOUR INK CARTRIDGE RECEIPTS, because if this happens to you and the cartridge is obviously new....the store of purchase should provide you with a replacement (+ if you don't want to make a 2nd trip, some stores have the mp830 on display and you can have them toss the cartridge in and check to make sure the chip is working properly). IF THE STORE WON'T REPLACE THE DEFECTIVE CARTRIDGE, contact CANON (USA 1-800-828-4040)and explain the problem & hopefully the will stand behind their product and replace the defective cartridge.
Posted on Sep 15, 2007
SOURCE:
When I turn on my MP830 Cannon the error "release the scanner lock switch and turn the power off and back on" appears. I have done it . The scanner appears to attempt moving, but does not get very far
hello, what i have found out so far, sometimes a small bit of tape they use on the scanner and ribbon cable rubs on glass, then catches on the white calibration area, but not all the time, when a machine has been used really well, and taken care of, the scanner just fails, replace whole top unit, not the doc feed, just scanner unit only, if main pcb still good machine will work just fine
Sep 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Scanning problem
I checked with the Canon Help Desk and wass told to uninstall driver for the Canon MP830 (unplug the USB Cable) and thn reinstall it. Hint: make sure you have your disc to reinstall befoe you uninstall, just in case.
Feb 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My fax is jammed and not printing does sender get an OK?
IF your scanner is working then you can send faxes it will stored in the printer memory and then send the fax..
Good luck...
Nov 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MP830 canon 3in1 scanner lock.
my mp830 will print, copy, fax but it will not scan to the computer. Please help
Sep 10, 2008 | Canon MP830 All-In-One Printer
Scanner is not operating correctly...
You have to download MP Navigator if you want to scan
May 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 wont scan
you have to use other programs such as photoshop to use the scanner
Mar 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Phone line and fax line
If you actually have a 2 line setup with 2 #'s each with it's own separate line, it's wired backwards. Otherwise (distinctive ring, etc) the machine has to be capable of and set-up to recognize which ring pattern is a fax call.
Also, you have to enable auto-answer on the fax machine.
Feb 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
1,189 people viewed this question
Clive
Clive
old marine
old marine
Ekse
