My A/C is not blowing very hard. It's blowing cool air. During the day it runs all day to maintain 78.
  • 659 Answers
Have you changed your filter? If you have changed your filter, the indoor coil is probably real dirty thus reducing the anount of air coming out of your registers. This will also cause the unit to run more because you don't have enough airflow to satisfy the thermostat. It can and might possibly be low on refrigerant but this alone will not cause a reduction in the amount of airflow you have. You need to contact a service professional to take care of this. This is not something that you should do yourself.
Posted on Apr 13, 2009
What is wrong with a air condition when it want cut off unless the number is set up?
Doesn't sound like anything is wrong. The number that changes is your set point temperature. (Your desired room temperature) So, if the room temp is 78 and you raised your set point temperature to 80, your machine would then kick off. Keep in mind this is when cooling. If you were heating it would do the opposite. Remember, if your setpoint temp is 78, the unit will continue to cool when it gets 78 simply because if it maintained exactly 78 all day long the unit would kick in and off 20 times per hour. Therefore most tstats will cool to 77 and not kick back on until the room temp gets to 79, preventing the machine from cycling too many times. Hope this helps!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 13, 2018 | Heating & Cooling
Air conditioner model 585CJ02450 doens't blow out cool air during the day at night blows cool air can I clean the filters and radiator
Was there any resolution? mine does the same it runs blows the fuse, but doesn't blow air out I would have liked to see what your resolution was.
Jul 12, 2012 | Heating & Cooling
M6X08F2A Air Conditioner problems not blowing cold, not cooling off apartment
Sounds like the heater is on as well. Even if ac is not working it shouldn't get hotter than outside air temp. Possible stuck relay.
Mar 01, 2017 | Maytag Heating & Cooling
Our A/c doesnot hold the tempeture set. If I set it for 78 as the day gets hotter it slowly climbs to up to 81. It will eventualy come back down to 78 after a hard day of work. If there is rainy day it...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 14, 2011 | Heating & Cooling
I live in a very hot climate, Yuma AZ. In the
It may be getting low on freon sometimes they leak out
Sep 10, 2009 | 2005 Dodge Durango
Fan is blowing but air is not cool, outside pumps
If I understand you have two units one top and one bottom. If one is not running you have a problem. It will cause the other unit to work harder. Check breakers and the basic things. But you may need to call a service tech ask for free estimate. Russ
Aug 17, 2009 | Heating & Cooling
Air coming out of vent very low and not cold
Try cleaning the coils with a wire brush and soapy water.
Aug 11, 2009 | Whirlwind FH-778 Air Conditioner
Does not seem to cooling very well
clean both the evap coil and the condensor coil
Jul 13, 2009 | Amcor NanoMax A12000E Portable Air...
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
