Question about Motorola Mobility E815
White screen When I open my phone the screen turns white
  • 3 more comments
  • Anonymous Jan 08, 2008
    I have the same problem, all I want to do is learn how to replace the flex cable. I am pretty confident about the rest.
  • Anonymous Mar 11, 2008
    • To open my Motorola e815 q not pass the screen is black and does not want to leave the
    • And I want to fix it but I do not know how that is what has
  • ashhhh Mar 23, 2008
    i have a samsung, and i dropped it, and now the screan is bright white! it still works and every thing, but the screen is blank. i have tried to take out the battery, and many other things, it still wont work!
  • Anonymous Apr 25, 2008
    when my motorola q is powered it just shows a white screen..no home page and nothing else...just white.. i took out the battery and restarted..but it just shows white...
  • iam2fly93 Aug 01, 2008
    i have a t-mobile phone and when i turn on the phone the screen is white..and i cant see what im doing.
I've tried to fix my motorola's ( v710's and e815's similar phone styles) that had the same problem with the flex cable. I have found that it's the inferior engineering of the phone that causes this phenomenon to occur. This happened to me when the hinge that attaches the display screen becomes worn due to normal use. It can become loose and then it stresses the area where this cable travels from the body of the phone thru the hinge up to the display. I am now on my 5th motorola.. after this one loses it's warranty I am not going with Motorola and instead getting an LG... those seem to hold up thru a 2 yr contract no problem...During my 2 yr contract I have gone thru 3 v710's and I am going on my 2nd e815... Too bad for this phone, when it works it's a wonderful phone.
Posted on May 29, 2008
We took our cell phone to the mall to a store called Wireless Expressions II. They fixed the phone in about half an hour -- took it apart, replaced the flex cable, and tested it to make sure the phone worked ok. Total cost: $10.75 including tax. Can't beat that price on ebay, not to mention the time it would have taken me to do it myself. If you want to try them, their phone # is 850-671-1100.
Posted on Mar 08, 2008
    Problem Solver:
  • 7 Answers
You can find the flex cable online at ebay. However, my opinion is that you should try to find a E815 or V710 that has a bad ESN or is somehow being sold for parts yet has a good LCD. That way you get the flex cable AND you get the chance to take apart the bad phone and get some practice. Plus you end up with parts for later problems. Good luck, I've been repairing these phones for a couple of years, you'll need some patience getting them apart.
Posted on Jan 24, 2008
  • 38 Answers
It is a flex cable issue.i had the same issue, did some research and found some people on ebay selling flex cables not too expensive, here is the link V710 e815 OEM Flex cable
Hope this helps.
Posted on Jan 22, 2008
  • 42 Answers
You may have a problem with your flex cable or dead pixels. Try and find a replacement flex cable. Most likely at any electronics store. If you have had your phone under 2 years (maybe 1) get a warranty replacement. Good luck.
Posted on Sep 11, 2007
    New Friend:
  • 53 Answers
Your flex cable has most likely gone bad. If the phone is under 1 yr. old I would suggest have it repaired by a warranty repair facility. If you are going to try replacing yourself let me know, I will try to help w/ disassembly. Good luck.
  • Nicholas Burress
    Nicholas Burress Sep 13, 2007
    I'm not exactly sure how my solution is any different than the one you rated FAR better, but just to let you know you won't find a flex cable for a cellular phone at many electronics stores so good luck.
SOURCE:
Slide the phone open and it went to a white screen. turned phone off but when turned back on it was still white screen. I could still feel the vibration when I received a text and I could still make a...
A white screen, especially on slider phones, is usually caused by a loose connection between the video output cable and the phone's motherboard. Unfortunately, opening the phone to access the cable voids the warranty, and is a delicate operation which risks damaging the phone.
Your best solution is to the contact your service provider. Most phones come with a 90 day - 1 year warranty on a service plan.
May 02, 2011 | AT&T Quickfire Cell Phone
My samsung screen is white but it works ive tried everything, this hbas happen before screen going white and the battery had to be without juice to come back. it works but ithe screeen is white
hi, the main reason the screen turns whits is due to the thin ribbon that sends the data from the circuit board to the screen being damaged what happens is that the thin copper wires that are inside the ribbon ware and then break causing a short to the screen and this is what turns the screen white. this happens on most flip and slide phones as the ribbon moves when you slide or flip the phone so over time it becomes brittle and you lose the connection and this turns the screen white.
sometimes it will right itself if you open and close the phone a couple of times but this wont be a long term fix how ever it may be that bad that this will no longer work, its not expensive to get this ribbon replaced but taking you phone to a small phone shop would be your cheapest option.
May 14, 2010 | Sony Ericsson K800i Cellular Phone
Screen is white. it turns on and off when battery
Either you accidentally dropped and spoilt your phone or water had managed to seep through. Try opening and get your phone screen out to wipe it clean (if you dare). Sometimes the connection can be bad from your phone to your screen if it's wet or dusty inside.
May 04, 2010 | Cell Phones
Phone works but screen either doesn't turn on or is white.
phone needs to be serviced or replaced!
Aug 20, 2009 | Cell Phones
White Screen When I sLide Up
just keep the phone slid up. i had to do that on my phone. and if i accidently closed it i waited til it went all the way black and then opened it again. or turn it off and on againuntil it works.
Jul 22, 2009 | Samsung Blast Cellular Phone
Screen gets distorted and turns white
the flexcable need to be replace on the phone
Jun 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Screen turns white when opened
Well what sometimes happens is your phone gets confused because when your cell phone is shut the screen doesnt go dark it is a plan white screen so what I think happend to your phone is that the sensor that is on your keypad is messed up somehow and thinks it is open when its shut.
The same thing happened to me before but my phone got wet.
Jan 22, 2008 | Motorola Mobility RAZR V3
Motorola Mobility E815 Logo
838 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
