Question about Dell Dimension 3000 PC Desktop
Added 2g to a dell dimension 3000, only 1g recognized
I had 2 towers and took a matched set of 1g sticks to upgrade my dell dimension 3000. The computer only recognizes 1g still, does that mean the motherboard only supports 1g? If that is the case is there a way to have all the ram used short of replacing the motherboard?
  • Dell Master
  • 4,338 Answers
Memory Upgrade for Dell Dimension 3000, the Dell Dimension 3000 takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 256 MB (removable) of Memory. You can upgrade your Dell Dimension 3000 to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 256 MB (removable) standard Memory installed. For best system performance use the maximum amount of allowed Memory per slot for your system.
1GB Module 128x64-400MHz DDR400 PC3200, 184p DIMM, 2.5v, Sync, CL=3.0 does this match the memory you have?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 13, 2009
  • 741 Answers
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Dell dimension 4700- added 2gb module in memory slot one, color coded white, and added 2gb module slot 3, also color coded white. only 2 gb recognized by computer, the second module is not recognized. ...
This motherboard uses inter-leaved RAM and RAM needs to be installed in pairs.
Check the BIOS RAM settings.
Try and use the same make of RAM.
One of the RAM modules may be faulty.
Try inserting the RAM module that was in slot 3 to slot 1
Feb 19, 2011 | Dell Dimension™ B110 PC Desktop
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
I want to upgrade my extenza from 1g to 2g or more how can i do on my own way, where we can find the memory slot.
its located underneath the laptop should be 1-2 phillips screws the ram sticks are inside push the tabs on the end's of the ram sticks they will pop up on a 45 degree angle remove them and replace with the amount you require if only adding 1 stick with an exsisting stick make sure to match ram speeds for better performance good luck
Nov 18, 2010 | Acer Extensa 4620 Notebook
Trying to upgrade t5082 emachines from 1/2 to to 2g. the only way it will boot is if I leave the 1/2g in slot one & put one of the 2g in slot 2. Is there a way to make slot 1 read the 2g?
Your motherboard has a 1GB limit per slot so the 2 GB sticks are simply not recognized. Take them back and replace them with a 2x1GB set if you still want to upgrade the RAM.
Aug 04, 2010 | E-Machines T5082 PC Desktop
Dell Dimension 4600 desktop memory upgrade
well first the mother board needs to be capable of handleing that much memory you can check that by going to the dell website and checking the specs on that model pc or mother board if the bios isn't recognizing it the chances are it won't but take out the 512 stick and just try one of the 1Gig if it does recognize that then try the second stick if it doesn't recognize them both then chances are it can't handle that much memory.
Oct 07, 2009 | Dell Dimension 4600 PC Desktop
I upgrade the memory of a Dell Dimension Desktop 9150 from 512 MB to 2 GB,The machine accept up to 4 GB..In the BIOS appear the 2 GB but on system in Control Panel only shows 512 MB..Can anybody give me a...
No you don't have to install a 64 bit OS. Only if you install over 3 gigs you MUST install a 64 bit operating system. 800MHZ is fine it will just back down to 667MHZ. your 32bit windows OS will see up to 3 gigs (minus graphics card memory). SO 2 gigs will work fine. Install one stick at a time and check in the OS and bios to make sure each stick works. I would say you possibly have a dead ram stick.
Jun 03, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
RAM sticks
Hi Runninthe8,
Please go to my site www.pc-fix.us and call the number there I'll answer and I can help you much more. If we proceed anyway we would have to call because you will need to turn off your PC when upgrading or adding RAM into your computer.
Look forward to speaking with you, Cameron Bradford
Sep 30, 2008 | Dell Dimension 8100 PC Desktop
Dell Dimension 3000 PC Desktop Logo
485 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
