Question about RCA HD52W59 HDTV Projection Television
RCA 52 INC MODEL R52WH77
I HAVE A CONVERGENCE PROBLEM. WHEN I GO TO SETUP THERE IS NO CONVERGENCE OPTION. WE GET NO PICTURE AT ALL. WHAT IS WRONG?
    Genius:
  • 1,030 Answers
From the symptoms you describe. you have the fl231 fuse problem. Congrations this is a simple fix. please read my article "the fl231 fuse problem" in the tips and tricks section
Posted on Apr 14, 2009
On our rca hdtv model # R52WH77.. the tv is having like a 3d look on it and has a bow in the picture.. we bought the convergance repair kit from tvrepairworld.com and replaced the 2 parts it gives us.. ...
have you reset the convergence parameters after installing the kit to fix the option? Usually you will need to reset the defaults to get the outer edges back in alignment.
Aug 11, 2011 | RCA R52WM24 52" HDTV Projection Television
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
I have a RCA HDTV model R52WH77 and the picture is like watching a 3D movie without the 3D glasses.
The ITC222 and ITC222A convergence option missing repair kit should repair that issue. The kits available at www.tvrepairworld.com and contains the parts and the CD with instructions
Oct 14, 2009 | Televison & Video
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
RCA 52inch Model R52WH77 HDTV
may i suggest reading the ariticle the fl231 problem in my tips and tricks section of my profile. YOu MAY have a 5 dollars 30 minuter fix. Determine if you have the convergence option under the setup option of the customer menu. if you dont then congratulations you have a simple fix. i you do have the convergence option and the autoconvergence then you might have other problems. and will have to troubleshoot further. If so ill talk you through some more. THIS set has NO stk convergence ics. my feeling is the fl231 which i see alot on this perticlar model at the shop
Oct 07, 2008 | RCA HD52W59 HDTV Projection Television
Rca 52inch hdtv
Please replace STK392-110 quantity 02 in your tv to fix convergence problem.
Above said part is available here.
Regards,
Sep 27, 2008 | RCA HD52W59 HDTV Projection Television
Tv help!!
ALright. you might have a simple inexpesive problem...MIght... first question If you go into setup menu do you have convergence option.. if you dont this it is a small special fuse that blows because of bad connections... can you solder electronic components. the parts about 5 bucks and takes less than 30 min to replace. Let me know if this is the case.
May 15, 2008 | RCA P52937 52" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
335 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
