Question about Canon Pixma iP6000D InkJet Photo Printer
IP6000D Paper won't feed at all then reads "out of paper"
I have this printer second hand so I am not sure on it's operation but I was told nothing happened to it and no jams but now it won't even move the paper.
When I go to print it starts up and the motor runs and some gears move but what I think is a kick plate does not move and neither does the right most rubber roller. I looked at the troubleshooting but nothing talks about it not even attempting to feed.
  • Anonymous Apr 20, 2009
    says no paper , load paper. Wont feed
  • Anonymous May 14, 2009
    I am having the same problem and can't figure out what to do!!
SOURCE: paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Posted on May 08, 2008
yooperbud
  • 8637 Answers
SOURCE: mp810 paper feed issue
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 27, 2009
  • 12 Answers
SOURCE: Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Posted on Jun 13, 2009
cabrooksjr
  • 13 Answers
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Posted on Jun 21, 2009
  • 20 Answers
SOURCE: paper wont feed
I had the same problem and it turns out one of my kids put a coin into the top of it and it was far down inside where i could not see it.and it was stuck in the bend of the paper feed after tearing it almost all the way down i finally was able to see it removed the coin and it worked.
Posted on Nov 03, 2009
IT WILL NOT PULL THE PAPER INTO THE PRINTER
Feed guide roller worn, or not making contact with paper in the path, or failed microswitch that detects the paper and initiates the paper transport process
Feb 10, 2011 | Canon Pixma iP6000D InkJet Photo Printer
How do I access the rear tray roller feeds to check if anything is stuck all of a sudden the paper is skewed on the right side and paper doesnñt enter the feed
You say the paper is scewed to the right which means absolutely nothing if you think about it, isn't the left hand side also scewed? Usually one side of the paper is pulled down leaving the other side up thus scewing it.
Firstly make sure nothing has fallen down the paper slot, secondly make sure the sliding paper adjuster to the left of the paper is up tight against the paper, even a 1 millimetre gap can cause this problem, thirdly look down the paper slot with the paper in and make sure there is no gap between the bottom edge of paper and plastic shute or case, you really shouldn't be able to see much of the two pieces of white plastic, now press the green start button.
Dec 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam error on Canon iP6000D
Hi Demo.
By the big gear...Do you see a clutch "with a hook like" plate ...check to see if it moves freely.
It sound like manual clutck is slipping .
Feb 25, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Paper jambs in the feed. The right side seems to pull down first then just jambs up.
Solution: Remove foreign objects from Rear Tray MP210
Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
  1. Close the scanning unit (printer cover).
    Caution: Be careful not to pinch fingers when closing the cover.
  2. Power the printer on and confirm that the printer operates normally.
    Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
And
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  1. Remove all sheets of paper from the rear tray, then click 'OK'.
  2. Confirm the following message, and click 'OK'.
  1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
  1. Click 'OK'.
Roller Cleaning is completed.
Cyber Kaka
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon ip6000D
hi,
use good quality paper for printing. clean the feed roller or get the printer serviced from the authorized dealer.
thanks
Aug 09, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Paper will not feed in Canon Pixma iP6000D printer
hi, clean the feed roller or get it cleaned from an authorized service center. use good quality paper
thanks
Aug 02, 2008 | Canon Pixma iP6000D InkJet Photo Printer
I have a Canon Printer.. Pixma iP6000D. I am trying to print out pictures. But everytime I try to load in my 4x6 glossy paper, the printer does not pick it up. I keep getting an Error to load paper. Is...
You do know that you can use 4 x 6 photo paper in the paper feed? or else you have to tuck it into that little try under the printing outlet and be sure to click the change of feed button on the upper right of the console.
Mar 19, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
Canon iP6000D - reads "No paper"
Unfortunately I don't know how to fix it but I do know how to get around it. Or at least on mine I do. My printer does the same thing to me even though I have plenty of paper. I've just kept inserting paper into the printer until it finds that "level" that it needs to say it has paper. If you find that level you can either continue putting in paper from that level on or put something underneath the paper like a way to keep the paper high enough so that it reads it properly. I know it's not a solution but it's a loophole of sorts.
Apr 29, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
261 people viewed this question
old marine
old marine
