Question about Canon PowerShot A75 Digital Camera
Dead canon powershotA 75
Was trying to do an firmware update on my canon but now its dead help it willnot power on i did try new battiers but no luck also it will not connect to the Pc win Xp ?
  • 2 more comments
  • Anonymous Dec 27, 2007
    My camera will not turn on after replacing the batteries several times with new ones.
  • flajoe Dec 29, 2007
    my camera will not power up. You recommend firmware. What is firmware? Nothing I try will start it. I try different batteries, but to no avail.
  • Anonymous Dec 30, 2007
    Yep, mine too. Just stopped operating and is completely dead. New batteries don't help. This has been a frustrating camera to own, my solution may be to hit it with a large hammer and move on.
  • ainebaine Dec 30, 2007
    how do you do this , where can i get a copy of the firmware?
Have you tried to put the original firmware back to the camera?
Posted on Dec 29, 2007
SOURCE:
Hi how to download firmware canon ir2318
It seems Conon does not have any firmware for the ir2318.
If you have any problem with any electronic device, DON'T try to solve this with a software update.
All updates have the same restrictions.
The system must have enough power to load and install the update (power cord is the best) and all systems should be working without any flaw. As soon as something is wrong, you can't be sure the update is loaded correct in the memory and installed.
Most factories, only release updates when they discover lots of bugs in the software. Providing the firmware comes with more warnings then I already gave.
If you want to try with canon? be my guest here is the link for support. Just fill in the model number.
http://www.usa.canon.com/cusa/page.action
Jul 18, 2014 | Canon Office Equipment & Supplies
Canon MF3240 firmware update failure
YOU THEN NEED TO REINSTALL IT BECAUSE YOU CANT ROLL BACK THE FIRMWARE
Mar 29, 2012 | Canon imageCLASS MF3240 All-In-One Laser...
My Sony P1i just went dead one day. it won't power up. Battery is fine. when u plug power the light glows and steady. repair shop says software needs reload, is there i can do myself, itried firmware...
My P1i appears completly dead after running Update Service. I've tried removing the battery, fully charging the battery etc. When i run Update Service again it just says my phone is up-to-date.
any suggestions?
Update only says "No new software is available for your phone. Your phone already has the latest available software installed."
Then gives the option to Exit only
Sep 05, 2010 | Sony Ericsson P1i
Have a canon mx700 printer. Its connected to a imac on snow leopard via usb. Ever since it was updated to new os version. It doesn't recognize the printer. I have searched online for the correct drivers...
First try a new USB cable and swapping ports. Make sure other USB devices work.
Software and drivers are here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#DriversAndSoftware (select OS from the drop-down menu then look for the notation of version 10.6). This site also has a firmware update for certain of these printers. Use the update with care, sometimes they will make a printer completely unusable.
I hope this helps.
Aug 30, 2010 | Canon MX700 Office All-In-One InkJet...
Error 99 comes up every now and then I can continue shoting though if Ieither take the battery out and put back in or open and shut the memory card slot, I've tried just getting a new memory card but that...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Nov 06, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Laptop willnot power up. I have checked the ac
It could be the battery which is at fault, take the battery out and try to boot it on AC power only.
Please post back with the results.
Good luck.
Jul 29, 2009 | Gateway MX6920 Notebook
Err 99 followed by the "Busy" issue in the viewfinder
I hope that helps.
Jul 26, 2009 | Canon Digital Rebel / EOS-300D Digital...
I have the same problem.
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Jul 20, 2009 | Canon Digital Rebel / EOS-300D Digital...
No power on Canon SD750
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jan 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Laserbase MF5750 Multifunction
@all: Firmware Update
Download the Canon MF Update Tool from the Canon Homepage.
Connect your Canon Laserbase MF5700 series to your PC and flash the Firmware.
Worked at my Canon Laserbase MF5750.
Had the same problem like you.
Nov 03, 2007 | Canon LaserBase MF5750 All-In-One Printer
Canon PowerShot A75 Digital Camera Logo
112 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
