Question about iiyama ProLite E380S-S 15" LCD Monitor
Iiyama ProLite E380S-S 15" LCD Whitescreen
When the monitor is connected and has power the screen shows a light grey colour and that is it.
SOURCE: colour changing
I found this on another site:
[QUOTE=numbnutjas]I had the same problem along with lots of others who bought this great prolite monitor.
Whenever you turn the power off for more than five seconds the monitor looses an important bit of info of a hidden menu. Iilyama are not keen on publicizing the fact their monitor has a bug!
Follow these steps very carefully, it might not work the first time but it does work I promise.
Make sure that the moniter power button is off.
Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.)
plug monitor back in mains.
hold down + and - on the monitor
now hold down power button on monitor
let go of power when power button when the green led lights up
let go of + and - buttons
wait a few seconds and press menu, a hidden menu will appear in the top right
use the + and - buttons to move the hilighted option over the auto colour option in the menu
push the menu button.
It does work, but if you have any problems: email at : miamoo2038 at hotmail dot co dot uk
Posted on Jun 05, 2008
thanks worked perfect
Posted on Aug 31, 2008
SOURCE: iiyama prolite h510 monitor is it vga compatible
i changed monitors
Posted on Jan 06, 2009
  • 82 Answers
SOURCE: iiyama Prolite E431S turns itself on and off
i think your monitor lose a power connection
Posted on Aug 31, 2009
Geekman
  • 32281 Answers
SOURCE: Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Posted on Sep 28, 2009
Can't get my Iiyama Prolite E2407HDS out of test mode
from iiyama tech support (UK):
  1. Switch off the monitor.
  2. Connect all 3 input types with live connections (VGA + DVI + HDMI)
  3. Turn the monitor on.
It will select an input and display as normal.
I have tested this and it does work!
Good luck
May 25, 2012 | iiyama E2407HDS-1 24 inch LCD Monitor
Iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
I locked my computer but i forgot my password. how can i unlock it?
Hello there,
The only way you can do this is to reinstall windows over your current installation, but not deleting your partition or formatting your drive. If you are not experienced doing this, I would suggest you take it to a Computer engineer.
Regards
Dec 06, 2009 | iiyama ProLite E380S-S 15" LCD Monitor
Display settings are out of range
you going to go to safe mode and try to restore you system to the date that you not change the video settings of computer just go to start button goto accessories click system tools and click system restore
Mar 11, 2009 | iiyama ProLite E380S-B (Black) 15" LCD...
Out of range
monitor is out of range you need to reconnect the old monitor and manually reduce the display resolution to say 1024x768 and see if you can start then you may also have to change the refresh rate to 60 hz in the display section of the advanced tab, hope this helps
May 09, 2008 | iiyama ProLite E380S-S 15" LCD Monitor
Out Of Range
Do the same procedure you do to enter "safe mode" but this time choose the "start in VGA mode" option, then change windows resolution.
May 08, 2008 | iiyama ProLite E380S-S 15" LCD Monitor
PC monitor wont come on.
Check that the power cord is fully plugged in first.
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you really want to fix this particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | iiyama ProLite E434S 17" LCD Monitor
Colour changing
Feb 23, 2008 | iiyama ProLite E434S 17" LCD Monitor
Speakers - no volume
double check that the speaker wire (green) is connected in the back of the monitor and into the back of your pc into the green connection, if it is and there is no sound you can always use a seperate pair of speakers, as it will be cheaper than repairing the monitor.
May 30, 2007 | iiyama ProLite E380S-S 15" LCD Monitor
iiyama ProLite E380S-S 15" LCD Monitor Logo
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
