Canon Pixma MP800 All-In-One InkJet Printer Logo
Posted on Apr 13, 2009
"PINK CAST" on all color printouts CANON PIXMA MP800
PINK CAST ON PHOTO PRINTOUTS Canon PIXMA PM800 I have been using my photo for almost a year ... this problem has always Twice I have contacted the support staff at Canon and carefully described the color problem on my Canon PIXMA MP800 ... on both occasions I was told there was no record of this type of a problem ... more than likely a change must be made to the PROFILE settings. Bottom line, we cannot help you. Last suggestion is for me to sent a printout of a photo that the pink cast is displayed and send it to the Canon support group and also send via email the same photo. I informed Customer Support that I have another printer ... one that came free with the purchase of a computer (Mac) ... no pink cast !!
Since then I have PURCHASED a HP OFFICE JET 6310 3 in 1 printer ($69) and again I do NOT have a pick cast problem.
This is troubling ... I purchased the PIXMA MP800 for one feature in particular ... the scanning of 35 mm slides. Checking the Online Canon Tech Support listing ... Quite a number of few people have described the PINK CAST problem on their printer.
CAN I RECEIVE HELP?
J P Finnigan [email protected]
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Mar 17, 2007
SOURCE: white bands across printouts
Either one of the print heads are bad or a cartridge. This is what causes that problem. I know it is a hassle but I would take it back. If try and fix it you could void the warranty.
Inky
Inky Fingers
  • 705 Answers
  • Posted on Apr 29, 2007
SOURCE: epson al cx11nf print problems: Lines on side of output
This could be caused by a dirty lens on the laser unit. Try cleaning the laser window. Open the front panel (where you change the toner) and the right you will see a blue lever/handle - pull it out towards you. Now on the right side panel of the printer you will notice a little plastic panel about 2"x0.75" - open that and you will see inside another handle. Pull this handle out and back in a few times. This draws a cleaner pad across the lens. If toner has fallen onto the lens it makes the are it has fallen onto create blank lines on the print. If this does not solve your issue then the next suspect would be the PCU. Just get another one (same as C1100 if you can borrow one) and try it.
rosener
Rosener Guyano
  • 103 Answers
  • Posted on Feb 06, 2008
SOURCE: Ink blobs on edges of printouts
Dear sir,
I figured out this problem it may cause; The problem behaves strangely why only on the right section the printout is not fused. The common section I first check is the high voltage circuit causing no static properties the powder shall be fused with the drum's developer. Now, it is clear also that the cause is within the drum. Pls check drum's life by printing the machine diagnostic details to check all moving and consumables counters. Clean the drum by rotating the developer roller. Well see if there's a irregularity of powder distribution. Have a nice day.
Anonymous
  • Posted on Mar 02, 2008
SOURCE: ip4500 printouts have lines through them
What kind of lines, horizontal or vertical? Are they colored or black streaks, or white (no ink)?
Thin white horizontals are probably a clogged nozzle. From you maintenance menu, run Printhead Clean once, then do a nozzle check. If that hasn't cleared it, do the deep clean, then nozzle check again.
Thick and/or irregular verticals may be dirty rollers (did you accidently print on the wrong side of your photo paper?) or a glob of ink on the printhead. Open the manual and check the instructions for roller and/or backplate cleaning.
Anonymous
  • 32281 Answers
  • Posted on Apr 01, 2009
SOURCE: Laser jet produces printouts that are smudged and dark
Remove the toner cartridge and use a soft cloth to wipe the photo drum clean of toner. Put it back and try again, if you still get bad prints, then you need a new toner cartridge.
Canon mg 3550 alignment problem?
Dear sir
I have encountered this problem on other printers. Try to clean the ribbon sensor found just above the head. It is a plastic digitizer strip used to align the head movement. Usually it has some grease on it just clean it with some cloth very gently.
Mark Borg
2helpful
2answers
Canon PIXMA 258 Photo All-In-One Printer color catriade cannot recognize
it is your cartridge connector..all you have to do is remove the cartridge and get a piece of soft cotton and alcohol...as you can see in the cartridge there are dots looks like a gold.. rub it gently using cotton with alcohol until it cleans.
i hope it will help you..
Light printouts
The problem you are describing seems to be one of Genuine parts compatibility? Are you inserting the Canon replacement cartridges
? if not then the printer will fail to communicate with them. I had the same problem, unfortunately these replacement/s carry printed circuits with information chips that only communicate with their genuine machine/s.
If the cartridges are genuine then maybe a fault on their circuit boards/chips and should be returned to the seller.
I hope this helps?
Canon I960 inkjet printer color shifts
We are experiencing something simillar with our imagepress. As far as I know, every heavily used Canon (or used for a longer period of time) tends to skew colors towards magenta a little bit. We are dealing with it by reducing magenta in color balance menu for all jobs on the printer, but the result is never perfect (especially in grey where is needed perfect balance of colors).
IP3300 Problem with greyscale photo prints
Have you tried configuring the paper options for the type of paper you are using?
Color problem
Chances are your othe cartridges were low...
When you install a new cartridge your printer does a head cleaning, and it uses alot of ink...
If the others were low, your printouts will show magenta as its the only color left...
Bad quality printing from the black cartridge
Select the correct Media Type setting (Windows)Print an image from another source
Change the Print Quality Settings (Windows)
try these if they dont work time for print head replacement.,
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10236
White bands across printouts
old marine
old marine
ZJ Limited
ZJ Limited
