Question about i-mate JASJAR Smartphone
Rom update failed
During the rom update my phone switched off and after about a minute an error code came up saying the phone wasn't connected. Now the phone is completely dead and will not start at all. Help!!!
  • 78 Answers
Hi, Sadly this will be a specialist repair. The ROM chip inside your phone is now corrupt as the information being written to it, did not complete. You may have seen the notices about not switchin off the power or running from the battery while carrying out this procedure. This may need a new rom or even a board. Without a special tool to re-write the ROM you will be unable to repair this. Not many places have these tools. Sorry it's not good news :(
Posted on Sep 11, 2007
SOURCE:
Why is my magicolor 4650en showing service call c025
Konica Minolta Magicolor 4650EN Error Codes
Code
C025
Display
CONTROLLER ROM
Description
Controller ROM error (Configuration information error)
• Lead error of destination setting file is detected during the printer starting.
Remedy
1 Reboot the main body. 2 Check the PRCB connector for proper connection and correct as necessary. 3 If this error message is displayed after update of firmware, conduct the firmware update procedures again. 4 Change PRCB.
Feb 16, 2018 | Office Equipment & Supplies
Xbox code 416b-0000-3080-0504-8007-0070
If you have personally, or had someone else, modify the firmware on your console's DVD-ROM drive to play burnt games, you will need to restore the drive to its stock firmware and then finish the update through that. You can then reflash the DVD-ROM as desired to play any new games you wish.
If you have not modified your Xbox 360's DVD-ROM drive, then it is likely that your console either has a DVD-ROM that is failing, or it is simply having trouble putting the DVD-ROM into flash-ready mode to accept the update. To attempt to fix this error, eject the DVD-ROM tray and then pull the power cord out of the console, thus preventing it from automatically injecting the tray. Next, push the tray in about half way, with about a finger's width of room between the console's shell, and the apex of the curve in the hollow center of the DVD-ROM tray. Then, plug in the console and power it up while holding the tray in that position to prevent the console from injecting it automatically. Expect resistance, but it will eventually give up trying to move the tray. From there, you can release the tray and allow it to update as usual. Do not inject the tray by hand, let the console reset the tray on its own after it finishes updating. That should fix your problem if that was the specific problem causing the error. Either way, good luck, and I hope your error is resolved.
Apr 17, 2014 | Microsoft Xbox 360 Console
Ive got network ploblem with my rxv673 yamaha amp as i brought it today and i cant do anything with it now as it say ROM ERROR can you help?
Looks like an online firmware update failed, mine did the same. Go to the Yamaha download page download the latest firmware to a USB stick and follow the instructions to run the upgrade from there.
Nov 23, 2012 | Yamaha RXV667 Receiver
1005ha bios update usb
Upgrading BIOS is dangerous and can cause fatal damage to your PC. If you are aware of that and decide to take this risk, then continute. 1. Visit http://support.asus.com/download/download.aspx?SLanguage=en-us, search 1001HA and choose DOS as operating system. Download latest bios rom file.
2. Save and extract the downloaded file. You will get a rom file named like "1301.rom" 3. Format a usb pen drive to FAT-16 partition. In my case I used a 32 MB SD card which came with my old Kodak camera, and I used a SD card reader that PC can see it as a usb disk. Copy 1301.rom to its root folder and rename it to 1005HA.ROM. The reason for renaming it to 1005HA.ROM is that EZ Flash on this 1001HA netbook looks up rom with this name. If EZ flash failed saying trying to find a rom file with another name, just shutdown the netbook and rename your rom file to the required name and try again. 4. Plug in the usb pen drive and reboot the netbook. Make sure that during the ASUS splash screen, press ALT+F2. Then EZ Flash will run automatically and try to locate the usb drive and read from file 1005HA.ROM (in my case). 5. It takes around one minute for me to upgrade everything. DO NOT TURN OFF OR EVEN TOUCH YOUR NETBOOK DURING UPGRADE. Read the messages on the screen and when it says you can press the shutdown button, you can turn off your system. 6. Turn on your netbook again and enter BIOS to check if the BIOS version is up to date.
http://www.youtube.com/watch?v=61awfpVe49k&feature=player_detailpage
Jun 11, 2012 | ASUS Eee PC 1005HA Atom N270 TFT Notebook
I can't turn on bluetooth for htc hd2. it said" Error in loading the Bluetooth stack (oxi)
Hello Tuy,
It seems that you have to update the software of HTC HD2 Smartphone. HTC provides Rom Upgrade in which it completely replaces the built - in software in the phone. Rom upgrade in the HTC HD2 Smartphone extends its features, imroves its performance which makes it easy to use.
Download the Rom Upgrade from the link provided below :
http://www.htc.com/www/SupportDownload.aspx?p_id=297&cat=2&dl_id=856
Rom upgradation completely erase the personal data and the customized settingsor any installed programs in the
HTC HD2 Smartphone. Before Rom upgradation pleas backup all your data.
Please visit the below links to backup your data before upgradation :
http://www.htc.com/www/howto.aspx?p_id=297&id=191
http://www.htc.com/www/howto.aspx?p_id=297&id=187
During ROM upgrade, make sure that your phone battery is at least 50% charged. Automatic standby and hibernation are disabled in computer, and close all running programs. Do not disconnect your
HTC HD2 Smartphone from your computer while the phone software is being updated. If you disconnect the HTC HD2 Smartphonee during the software update, it may become unusable.
Jun 05, 2011 | HTC HD2 Smartphone
Maxdata tower computer : - when switched on bleeps 2/3 times and doesn't engage the mouse or the keyboard and the monitor shows " no video input ".Just no response and doesn't turn itself on...
BIOS Beep Codes
Whenever a recoverable error occurs during POST, the BIOS displays an error message describing the problem. The BIOS also issues a beep code (one long tone followed by two short tones) during POST if the video configuration fails (a faulty video card or no card installed) or if an external ROM module does not properly checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors, usually consisting of one long tone followed by a series of short tones. For more information on the beep codes issued, check the documentation for that external device.
There are several POST routines that issue a POST terminal error and shut down the system if they fail. Before shutting down the system, the terminal-error handler issues a beep code signifying the test point error, writes the error to I/O port 80h, attempts to initialize the video and writes the error in the upper left corner of the screen (using both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to the operating system.
I hope this helps.
Mar 14, 2011 | Computers & Internet
New connection setup database found. do you want
This is a known HTC problem. It can to be solved for specified ROM versions only. Unfortunatelly ,this is not my version.
http://www.htc.com/hk-en/supportDownload.aspx?p_id=179&cat=0&dl_id=481
Jul 11, 2009 | HTC Touch HD Smartphone
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
Not Loading Up
You may be in need for a ROM update/reinstall. It is pretty easy to do that. You can either go at HP's web site and download a ROM update for your specific model. Make shure you select your operating sistem rigt. Or you can browse the internet for a specific ROM update for your model. I recomand the HP site, and if you have problems regarding the ROM update process, or the ROM and OS version you need, please reply here and I'll guide you throught. Good luck.
Jan 18, 2007 | HP iPAQ H4150 Pocket PC
i-mate JASJAR Smartphone Logo
60 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
