Question about Video Cameras
The camera wont turn on, period!
The camera will not turn on at all! it has brand new batteries, and its never been dropped or damaged or anything like that.
  • wb92173 May 11, 2009
    Exactly the same thing. Mine was never dropped and is only 3 months old. New batteries and it won't turn on.
  • Anonymous May 22, 2009
    the camera won't turn on period I charge it up taking the battery out and charging it for 8 hours then putting it on doesn't do anything never dropped only used maybe 8 times.
    Sergeant:
    Champion:
  • 396 Answers
Never been dropped to the best of your knowledge. Try plugging it in with the new battery in it and let it charge for a day. Then see what happens. Make sure there isn't any sort of protective film or anything preventing the battery from making contact. ALso take a light and look cvery closely with a magnifying lense inside the battery compartment and observe if there is any sort of corosion or lisalignment etc.
Posted on Apr 13, 2009
My Camera (Sony Cyber shot DSC-H10) Will Not turn on. PERIOD. Please Help
There is an internal battery that you cannot change that goes bad and then the camera wont come on. You have to send it in. www.unitedcamera.com
Mar 18, 2015 | Sony Cameras
My fujifilm finepix s8500 will not turn on and the light flashes red when i try to turn it on
Always be sure the battery is charged and suited for your camera.
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth, Or a cotton swap. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Never use manganese (Zinc-Carbon) batteries in your camera.
Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
When, while shutting down, the lens got stuck, the camera won't see it on the correct place when switched on.
When you are sure you have good and charged batteries with clean contacts, reinsert the batteries and switch on again.
If that does not solve the problem, switch the camera off and feel if al slight pressure on the lens barrel, will help the lens go in. Never use force, because you can damage the lens motor or the gears.
May 26, 2014 | Cameras
Tried 6 sets of batteries all brand new. The camera wont turn on, it has not been dropped and there is no damage.
Sounds like the camera has gone bad. If its under warranty I would get it swapped out asap.
Jul 15, 2011 | Kodak EasyShare C913 Digital Camera
Well i was recording a video on my camera and i drop it on the sidewalk and it wont turn on so can u please help me please i dont want to by another one
  • Make sure you have all the parts of the damaged camera. Don't leave the spot where you dropped your camera right away. Gather all the pieces and put them in a Ziploc bag or a container.
  • Step 2Check the camera for damage. Make sure the battery fits tightly. Turn on the camera. If there is no error code on the screen, check the camera's other functions and features. A broken lens can't be fixed. It can only be replaced.
  • Step 3If your camera is damaged, don't try to fix it--especially if it is expensive. It's not worth the risk of doing further damage. Fixing a camera requires a lot of knowledge and skill. Specific brands require specific technicians.
  • Step 4Go to the nearest service center for your camera brand or to a repair shop. Service centers won't fix the camera for free (unless you bought supplementary coverage or have insurance). Sometimes a repair costs almost as much as the camera itself...
    TRY THAT :) ♥♥hope it helps!
  • Jun 30, 2010 | Cameras
    My camera wont turn on and i bought new batteries
    If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
    Dec 15, 2009 | Kodak EasyShare One Digital Camera
    Camera wont turn on/off
    I went to another problem, knowing my camera was stepped on, I messed around with moving the lens part around, barley moving it, and then I tried holding the on/off button and the button to take the pics with, and then put in new batteries and it turned on. I would suggest doing that.
    Aug 28, 2008 | Sanyo VPC-S500 Digital Camera
    DIGITAL CAMERA
    clean the battery and battery compartment with alcohol and let air dry for an hour before inserting battery
    Dec 20, 2007 | Olympus SP-700 Digital Camera
    Wont turn on!!!
    My problem is this; i changed the battery after i had signal that battery should be changed. I changed the batteries with new one but when i press the on/off button, the camera will turn on.
    I put in new batteries again and is still the same problem.
    Mar 11, 2007 | Vivitar ViviCam 3765 Digital Camera
    Video Cameras Logo
    300 people viewed this question
    Top Video Cameras Experts
    Are you a Video Camera Expert? Answer questions, earn points and help others
