Question about RIM BlackBerry Pearl 8100
My blackberry curve wont load, it wont go passes the screen with the little hourglass
    Scholar:
  • 57 Answers
Hi there!
It's possible that a quick power cycle might help you.
Take the battery out of the device, press the power button 10 times and on the 10th time, hold it down for 10 seconds. This will drain all remaining power that still exists in the Blackberry.
Place the battery back in and attempt to boot the device to its normal state.
Was the device damaged in anyway that might cause this problem? If dropped in water or dropped on the ground from a notable height, you should definitely have a technician take a look at it. You can find a technician at one of your service provider's device support centers. Or, if you don't want to have to go anywhere to troubleshoot, you can contact Blackberry Support on a different phone and they should be able to help you.
Also, if you have a warranty plan, this would be cause to utilize it.
I hope this helps! Feel free to reply if you have any further questions.
Posted on Aug 31, 2009
MY blackberry wont go past the hourglass screen, I updated my bbm an this happened, how can I fix it?
Posted on Sep 28, 2009
    Sergeant:
    Champion:
  • 223 Answers
Take your battery out for a minute and put it back in...it will reload on its own.
Posted on Jun 17, 2009
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
App error 523 on blackberry curve i cant fix
Hello
App Error 523 usually happens after loading incompatible 3rd party software. Did you load anything lately? You should be able to connect to the device while it's rebooting (spinning hourglass) with application loader and remove the offending 3rd party application.
Good Luck, and do rate the solution if got help
Dec 11, 2010 | RIM BlackBerry Curve 8520 Smartphone
Hi , i bought a curve 8520 3 weeks ago and it has been brill ,however last night the screen went white wiv the hourglass..i hav took the battery out for several hrs..and then replaced it...and my phone...
The BlackBerry has the feature on auto-start. When you insert the Battery, the device will automatically boot-up. It'll be showing an hour glass while loading the settings. But if it is longing for more than 10 minutes, there might be some error in the OS. It's better to contact a near-by authorised Service Center.
Regards
Vineeth K.
Aug 05, 2010 | RIM BlackBerry Curve 8520 Smartphone
My blackberry keeps loading , ie the hourglass icon comes on everytime prior to receiving a message and or a call . And the call is disconnected ,
Your system is corrupted.
First backup your data
Then on your blackberry navigate to the following sections:
  1. Options menu
  2. Security Options
  3. General Settings
  4. Menu
  5. Wipe handheld
Then restore,
Nov 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
Curve with white screen with hourglass and red light on
If the flipping hourglass stays for longer than 2 min our Blackberry may just need a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings.Download the Blackberry Desktop manager and run the application loader. Make sure you check to delete old applications in advanced tab. Carefully all you datat will be wiped.
Aug 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
BLACKBERRY WONT GO TO MAIN SCREEN
Your operating system might be corrupted you would need to reinstall it by connecting it to a computer running desktop manager and has downloaded the right operating system and installed that on the computer aswell then everything should fix itself once you have installed the new operating system on there.
Kyle
Jun 17, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry curve won't turn on...
Wipe it to start over. Sometimes when you change or add something like a THEME or a download it HOSES the BB completely. So delete what was on there and don't download a theme or any other wacky add-on.
To Sanitize or Clear out all the information in a Blackberry Device
Scroll to select the OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY and press [Trackwheel] to select.
On some units you may have to select GENERAL SETTINGS before getting the next menu.
Press [Trackwheel] again to access the Menu screen for the security.
Scroll to select the WIPE HANDHELD and press [Trackwheel] to select.
Scroll UP to select CONTINUE and press [Trackwheel] to select.
Type blackberry on keyboard to confirm the action press <-| key.
System responds with ERASING INFORMATION.
Mar 19, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Slow loading time
you need to update the software on your phone you can as an over the air update which i do not recommend or you can do at T-Mobiles website the easiest way to find is to go to blackberry.com and search for the version 4.6 curve update
Feb 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Hourglass comes on 5-6 times a day and screen goes black
You probably need to update your software to the latest version. You can download it from your service provider or from RIM: www.blackberry.com
Dec 31, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry  Pearl  8100 Logo
1,329 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
