Question about Kenmore Dryers
The drum on my dryer won't move
I push the dryer button on and it just goes hmmmmmm and the dryer drum won't turn manually by me.
  • Michelle Kolbe Aug 16, 2015
    our drum wouldnt move either ...we took it apart and found a sock caught in the round thing that goes around where the lint gets sucked up in...made that stop going around and the drum wouldnt moved ...fixed successfully in about one hour ....
  • 30 Answers
Does it produce heat to dry the clothes? If it does it sounds like the motor may have burned out or disconnected, best to call someone out
Posted on Apr 13, 2009
Lg tdc70045e dryer
Sounds like your motor has packed up
Jun 13, 2013 | Dryers
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Old kenmore dryer, drum won't turn
Could have the motor frozen, (armature,bearings,etc) causing an overload on the circuit. Can you physicly move the drum by reaching in and turning it?
Feb 12, 2013 | Kenmore Dryers
My ED56 won't start unless you turn the drum by hand why?
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Apr 28, 2012 | Fisher and Paykel Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My dryer will turn on, when I push the start button the sensing indicator lights up, but the drum doesn't turn and no air flows. I had a tech come out and tell me it was the main control board. We...
Most dryers have a belt that goes around the drum attached to a spring pulley and the motor pulley, if the belt breaks. the drum will not spin. and most dryers also have a safety switch in between the door and the dryer, if this switch is bad,will not let the drum turn. most dryers have a vented slot in the rear of the machine at the bottom, if you remove this vent you should be able to see how the motor moves the drum. good luck!
Aug 19, 2011 | Whirlpool Dryers
The dryer drum does not rotate at all. The dryer itself will "click" on when I push the start button and you can hear the dryer and feel the heat but the drum won't move. We took the entire...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Dryers
Dryers Logo
98 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
