Question about SanDisk Sansa E280 MP3 Player
My sansa 3280r mp3 player just froze and can't turn it off - computer doesn't recognize my mp3 player
Press-down on the power on/off button for 20 seconds. that should force it to turn it off. however, should that fail, you can use small screwdriver to remove the four screws on the back... then lift-out the battery, and then put battery back in place.
Posted on Apr 14, 2009
It doesn´t recognized the music files
is the music files in the music folder? (its a hidden folder stupidly enough so is hidden files turned on in your operating system?)
are they mp3 or wav files? If the answers are no - now you know why.
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
I was charging my sansa mp3 player and now it does not work!!!!!!
the problem is when the computer freezes it sometimes can wipe the hard drive and can damage the mp3 player for good thus freezing it from turning it on and clearing the memory and thats it
Dec 27, 2008 | SanDisk Sansa Clip MP3 Player
My name is Joseph, and I own a red 2GB sansa clip player. I was using it when exercising when it froze. I turned it off, waited a few seconds, and then tried to turn it back on. But it would not turn...
http://www.sandisk.com/techsupport
Have you tried resetting the player, slide the power switch up and hold it for 15 seconds, see if this helps. If not click on the link above for technical support from sandisk.
Dec 08, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e200 is not recognized by by computer
**** this sansa e260 the piece of **** froze on me twice and both times i took it back to circuit city and just got a new one. one suggestion when you do get this is keep the repeipt for it
Mar 31, 2008 | SanDisk Sansa e200 MP3 Player
Froze
This may be the mp3 player that is wired badly. However, you may taking the battery or disconnecting it from its power for 10-30 seconds. Also, power down the computer and wait for 10 seconds -30 depending on the amount of times the computer has been shut down for the week. Try downloading its driver so that the computer will recognize this hardware.
Feb 03, 2008 | SanDisk Sansa m240 MP3 Player
My sansa froze up
try the reset the whole thing solution
go to recovery mode, then run the
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
i dont know if itll work but its worth a try
good luck
Feb 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa c200 froze.
Pop the back cover off and take the battery out...when you place the battery back in and restart you should be ok.
Jan 02, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e250 froze
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 30, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
124 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
