Question about Sony STR-V555ES Receiver
Audio Video Receiver Problems
My Sony V555ES when in surround sound mode all but eliminates the voice track. Sound can be heard from center channel but back ground noise and very very week voice track. Also recently it has started to kick itself off (thinking a surge protection) when loud noise such as gunshot is in the track. This is at what I would call moderate volume levels below what used to be ok on this receiver. Turning off/on resets. I'm debating taking in for repair or replacing this unit
  • 752 Answers
It sounds like the center channel isn't plugged into the correct speaker output. Unhook the speakers and reattach them while paying VERY close attention to which jacks you're putting them in. Report back with results.
Posted on Sep 11, 2007
Sony STR-DG710 center speaker makes no sound. Connections are good.
Sometimes these units have the ability to switch the speaker off and on. Look up the speaker settings in the manual.
As each channel in the unit will be separately driven the power amp for the center channel could have failed, but I think it's unlikely unless you have had problems with the sound on it before, or connected it wrongly causing a fault.
Dec 16, 2016 | Sony STR-DG710 Receiver
Hooked to surround sound, two front speakers, 4 wall speakers, 1 sub woofer. Restart unit and reduce volume unit is OK but normal talking is too low.
Voice tracks are usually routed to the center channel. You don't mention having a center channel speaker hooked up. If this is the case, then you need to go into the receivers setup menu and set it for no center. This will reroute the voice tracks to your front speakers.
Feb 24, 2016 | Onkyo TX-DS575 Receiver
HELP! Surround speakers not working with 5.1 material.
This may sound silly, but . have you checked your sytem setup settings to make sure it is set to 5.1 ,if so then you may very well have a bad channel
Mar 29, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
No sound from center channel
If you have checked the speaker and wiring. Check the setup, the center channel could be off or it's not in a surround mode.
When playing a DVD through the receiver are the voices heard clearly in the front speakers? if so the center channel is turned off.
Oct 21, 2009 | Yamaha DSP-A1 Receiver
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
Poor voice track but great sound.
Unhook your center channel speaker and see if it still goes into protect.You might have bad center speaker
Sep 09, 2007 | Sony STR-V555ES Receiver
Sony V555ES Amp:
Try setting your amp to "auto format decode".
It should easily be heard in this mode.
The sub will not show up on the display when in 5.1 mode. (Blue light on)
Use this with music, and use the 5.1 with movies to get a better experience from your amp.
The sub will work in 5.1 but doesn't show up in the display. Try movies with loud sounds.
Most of the pre-set sound fields are of no use to me. I only use normal surround, and AFD and love it. I hope this works for you!
Terry
Jul 03, 2007 | Sony STR-V555ES Receiver
Sony STR-V555ES Receiver Logo
163 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
