Question about EliteGroup P4VMM2 Motherboard
My ecs p4vmm2 cannot open to windows
When i try open my cpu, bios rom checksum error appears on screen.. and also detecting floppy drive A.. then drive A error and then system halt.. pls help me to open my bios setup.. thank you!
  • derek0821 May 31, 2008
    when i try open my cpu, bios rom checksum error appears on screen.. and also detecting floppy drive A.. then drive A error and then system halt.. pls help me to open my bios setup.. i pressed the delete button and the f2 but stikk the same problem.. how can i fix it. help me please! thank you.
Help me, primary secondary is no detected
Posted on Jun 01, 2008
  • 2,961 Answers
You must have a faulty floppy disc unit, you need to press F2 or Del to get into the bios and check the time and date if they are wrong then the cmos battery needs changing.
Posted on Sep 11, 2007
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
When i boot the computer what comes on the screen is (''award bootblock bios v1.0'' copyright(2) 2000, award software, inc bios rom checksum error detecting floppy drive A media insert system disk and...
it means your boot sequence is first booting your floppy drive or your hard disk is not detected.i think you should check the cmos can set it by pressing delete while the pc is booting.disable floppy drive seek.also the boot sequence.the os installed is maybe corrupted, is also one of the problem. refer to the manual if you have.
May 16, 2009 | Computers & Internet
The following message appears as soon as I turn PC on; BIOS ROM CHECKSUM ERROR Detecting Floppy Drive A Media... Insert system disk and press enter My OS Microsoft Windows XP SP2 Bios : Award Bios...
There should be a jumper beside your bios batery there should be 3 pins move the jumper to the last 2 pins for 5 seconds and put it back that should do it
Mar 23, 2009 | Computers & Internet
P4vmm2 v8.1 bios checksum error
Try to reset your Bios by remove the CMOS battery
if it's just same
you can to replace your CMOS chip in your board with the same type ( you can get it from useless or junk 'same type' motherboard)
Nov 05, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
My cpu won't boot
Is there a disk in your floppy drive?
Do you use the floppy drive at all? (Most people no longer do)
If you don't, unplug the power, open the case, disconnect the floppy drive.
Plug it back in, power it on, and go into the BIOS setting screen (depending on the computer, there are different things to do, like hit the DEL key, or F12, or F2, or ESC etc)
Once you are in the BIOS screen, disable the floppy drive detection, save it and try booting again.
It sounds like your floppy drive has gone bad. By removing it, and disabling it in the detection, you can get deeper into the problem (if there is one after that)
Sep 03, 2008 | Intel Motherboard
Checksum error
Hi Oliver, the most common error related to the message,
(Bios Rom Checksum Error). Someone has left a floppy disk in the floppy drive. Once the floppy disk has been removed press the reset button on the PC, your windows will start normally. Next place to look is in your bios.
Open your manual to page 27.
Enter your bios & go to the title Advanced BIOS Features. Check First, Second & Third boot devices they should be as follows. Floppy disk drive, CD-ROM drive & primary hard disk drive. If both of the above are ok than try clearing the cmos/bios by resetting the cmos jumper (JP1) location on page 5. Descriptions of page five on page 6. CMOS settings on page 9.
When your system restarts re-enter your cmos & reset up your bios settings. Lastly if none of the above has fixed the error message, than remove the cmos battery & check its voltage. It should maintain 3volts. If yours' is lower than 3volts replace the cmos battery. There is one other possible fix. It’s an option not given lightly. Flashing a cmos/bios is not recommended unless all other options have failed.
Bios link for the EliteGroup P4VMM2 V8.1
Main web site;
Good luck Oliver!
Aug 23, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
EliteGroup P4VMM2 Motherboard Logo
154 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
