Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Husky 455 dies out at full throttle or under load
Saw starts and runs fine at idle. runs fine at half throttle under no load. dies quickly at full throttle or under load
  • 1 more comment
  • mrreyn00 Apr 14, 2009
    as Mr Fixit says, First, clean your air filter and replace the spark plug. then start with carb adjustment, next it could be dirty carb. I had the same problem with my 61, but after doiing all this (and I completely took my carb apart and made sure all passages and screens were clear), I was still having the same problem. Make sure to take note how to put it all back together. I put 1 gasket on backwards and covered up a hole that feeds the cylinder, believe me, your saw won't run at all then.
    If that doesn't fix it, it could either be blow-by in your piston/cylinder when putting load on the engine or the ignition system is going bad. If you have a compression tester, this is a simple process that will only take a few minutes. Otherwise, the strength of the spark may be your problem, not strong enough to power your saw under a load or at high rpm's.
    I have done all the cleaning and checking and found my compression to be a bit low. I took of my cylinder and had some light scoring along the exhaust port side. I ended up replacing my cylinger, piston, rings for $60 off ebay, nice kit from Kafar. However, once I got back to full compression same issue. It seems 1 of the 2 pieces of my ignition system were no longer able to deal with the extra compression (I have the god awful old 2 piece system and no way to test which one is bad)
    An ignition system must be healthy enough to fire a plug under compression. This seems to be my issue, since it is even more pronounced now with normal compression. Hopefully, you don't get this far along, but it could get this far.
  • Anonymous Apr 18, 2009
    The chaisaw will run fine while idleing but as soon as you increase the throttle it dies out
  • Anonymous Apr 20, 2009
    I have the same problem only it is more pronounced when the saw is hot. Seems to run and cut much better when it is first started.
    Problem Solver:
  • 7 Answers
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Posted on May 03, 2009
  • mrreyn00 May 07, 2009
    REPLACE YOUR FUEL LINE!
    I thought my saw ran great, but it died once I ran it at full throttle for a few sec's.
    IT WAS THE FUEL LINE. A simple and cheap fix, takes minutes with right tools. Popped it in and my saw runs better than new, given I've replaced about everything.
2 year old TS410 no power recently, was serviced , correct mix but dies when pressure comes on ,blade stops, starts fine and runs idle fine-tom
Hi Thomas its probably had its high/low screws reset and whilst it runs fine on the bench under load its running weak try unscrewing the high screw out a half a turn
Aug 16, 2013 | Stihl Ts 410 420 Cut Off Saw...
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
Bought a new husky chainsaw a 455 rancher. was told i had to break it in on small logs & not run it very long at first. is this true
The factory usually recommends 2-3 tanks of fuel going easy on the saw and not running at full throttle.......but I have never done this on any of my saws and I don;t know anyone who has and my saws are all still running great.
May 20, 2011 | Garden
I have a 350 husqvarna, starts up fine, runs fine when at half throttle, when u put into full throttle it lacks power and backfires, go back to half throttle runs fine
This is classic fuel starvation, start by removing the fuel hose from the tank and replace the filter on the end, if no better, it may be a tank breather issue, when the saw starts to die slacken the fuel cap, if the saw picks up you need to replace the breather, if no better you can make a small adjustment to the H screw on the carb, unscrew ( counter clockwise ) the H screw this will richen the mixture, you will need to pull the anti tamper sleeves back on the screws, this can be done by gently screwing a suitable self tapping screw into the sleeve, when it hits the screw head under neath the sleeve will start to pull back, once pulled half way off you can enter a 2mm screw driver through the centre if the sleeve and intp the slot in the adjuster screw underneath.
Mar 01, 2011 | Husqvarna 350 Rancher Chain Saw
Chainsaw dies at full throttle, idles fine and works with half throttle
hi
check the fuel filter,clean the gas tank,the carburator ,check the fuel pump(not to be tired).the fine filter inside the carb under the fuel pumpand the sparkplug.
by for now savumihai71
Oct 29, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husky 455 rancher.never had a problem till today, worked fine this morning, now it iwll start but as soon as i put it under load it dies, cannot even rev the engine, it idles ok, but once i open...
When this has happened to me, it turned out to be a hole or crack in the fuel line. At the higher revs, more fuel is needed. The added "suction" for the higher demand pulls air into the line and the unit does not have enough fuel to run. Check for that first and also the fuel filter inside the tank. The filter might be clogged as well.
Keep us posted,
Dan
May 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna ranger 55 chainsaw starts but quits
Sounds like it could be fuel starvation. I just had a case of exact same except mine finally worsened. Most likely and what I just encountered, its your fuel line. It's a quick and simple fix and you can do it yourself. Youtube has several videos showing you how to do it. Feel your tube, if it feels soft or spongy, it's probably got cracks or even a pin hole somewhere. It's $10 and as I've learned, one of the most common fixes when saws start cutting out at full throttle or under load. My dealer said he's been through 15 of them in the past 3 months.
May 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw kills when I press the throttle
My 372 xp did that and when I talked to the repair shop they even showed me. There is a fiberglass gasket that is used to mount the carburetor to the engine. I have no idea on how this happens, but I saw it with my own eyes. The gasket had actually folded over. They replaced it with a rubber one and have had no problem since. The saw was hard to start, would run as long as I didn't try to cut anything and when I did it would open up and then die. I could be giving wrong information, but that sounds exactly like the problem I was having.
Oct 08, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
4,746 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
