Question about Jensen CR-560X Cassette Player
Can't find install manual for my Jensen CR560X car radio. Any special removal tools to pull the receiver out?
  • 15,935 Answers
CLICK HERE for your manual.
After removing the trim ring you will see a slot on each side to insert the removal keys.
Generic keys are used. (top left in the pic)
Sometimes you can use thin allen wrenches or wire coathangers.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 13, 2009
How do I remove the instrument cluster dimmer switch in my 2000 Lincoln town car
Switch - Panel Dimmer
Special Tool(s) syg~tr~en~file=st1445a.gif~gen~ref.gif Radio Removing Tool
T87P-19061-A Removal
  1. Disconnect the battery ground cable
  2. Pull out the radio using Radio Removing Tool.
  3. Remove the radio.
    1. Disconnect the electrical connectors.
    1. Disconnect the antenna cable.
    1. Remove the radio.
    2. Remove the instrument panel finish panel bolts.
    3. Remove the instrument cluster finish panel bolts.
    4. Pull out and position aside the instrument cluster finish panel.
    5. Disconnect the electric clock electrical connector.
    6. Remove the instrument cluster finish panel.
      1. Disconnect the headlight switch electrical connector.
      1. Disconnect the dimmer switch electrical connector.
      1. Remove the instrument cluster finish panel.
      2. Remove the dimmer switch.
        1. Remove the screws.
        1. Remove the dimmer switch.
    7. Installation
      1. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
        To install, reverse the removal procedure.
Nov 29, 2015 | Lincoln Cars & Trucks
Clarion nz409 how to remove properly from dash .
Yes you will need the keys that came with the radio. If you cant find them you will need to go somewhere like radio shack or somewhere else that installs car stereos and have them remove it for you.
Mar 25, 2012 | Clarion Car Audio & Video
I need to remove my 6 cd changer am fm radio how does ut come out please help so i can replace it
you need the radio removal u shaped tools. you can buy for $5 at uto store.
SECTION 415-01: Audio Unit 2002 Escape Workshop Manual
REMOVAL AND INSTALLATION Audio Unit
Special Tool(s) s2k~us~en~file=st1445a.gif~gen~ref.gif Radio Removing Tool
415-001 (T87P-19061-A)
Removal and Installation
  1. Disconnect the battery cables. For additional information, refer to Section 414-01 .
  1. Remove the audio unit.
    1. Insert the special tool into the radio face plate and release the radio retaining clips.
    1. Pull outward on the special tool and remove the audio unit from the instrument panel.
  1. Disconnect the connectors.
  1. To install, reverse the removal procedure.
Apr 22, 2011 | 2002 Ford Escape
How do you remove radio assembly from dash in 08 holden caprice ?
Is this a factory installed radio - or aftermarket?
Jan 29, 2010 | Car Audio & Video
How do i get the tape deck out to install a cd player?
Hope this helps! Please don't forget to rate!
Example of the special radio removal tool
Exploded view of the radio mounting and wire connections. Note the rear support and the bracket that it attaches to
  1. Disconnect the negative battery cable.
  2. On 1991-92 models, remove the finish panel from around the radio assembly.
To remove the radio, insert the removal tool prongs into the release clip access holes (arrows)
Push in approximately 1 inch (25.4mm) to release the retainer clips, then pull straight out to remove
3. Insert the radio removal tool T87P-19061-A or equivalent, into the radio face.
4.Press in 1 inch (25.4mm) to release the retaining clips, then using the tool as handles, pull the radio out of the instrument panel.
Disconnect the antenna ...
... and the electrical wire harness plugs from the back of the radio
  1. Disconnect the antenna and wiring connectors from the radio.
To install:
  1. Connect the wiring and slide the radio into the instrument panel. Ensure that the rear mounting bracket is engaged on the mounting track in the panel.
  2. If removed, install the finish panel
  3. Connect the battery cable.
  4. Check the operation of the radio.
Jan 10, 2010 | 1992 Ford Explorer
I need to remove the radio in my 1998 mountaineer
you need specail radio removal tools. they spread 4 spring clips.
  1. Remove the radio chassis.
  2. Insert Radio Removing Tool into the radio face plate and release the radio retaining clips.
  3. Pull outward on Radio Removing Tool to remove the radio chassis from the instrument panel.
Special Tool(s)
Radio Removing Tool
May 12, 2009 | 1998 Mercury Mountaineer
I need to change the bulb in the analog clock in my 1999 Lincoln Towncar. How do I go about getting to it without tearing apart the dashboard?
you need a special tool to get the radio out. It has pins that spread out spring clips so the radio can pull out.
please rate as solved if this helps.
SECTION 413-00: Instrument Cluster and Panel Lighting — General Information 1999 Town Car Workshop Manual
REMOVAL AND INSTALLATION Bulb —Electric Clock
Special Tool(s) Radio Removing Tool
T87P-19061-A
Removal
  1. Disconnect the battery ground cable.
  1. Pull out the radio using Radio Removing Tool.
  1. Remove the instrument cluster finish panel bolts.
  1. Pull out and position aside the instrument cluster finish panel.
  1. Disconnect the electric clock electrical connector.
  1. Remove the electric clock illumination bulb.
Apr 23, 2009 | 1999 Lincoln Town Car
2002 ford explorer radio removal and installation procedure
You have to have special ford radio tools. they look like two horse shoes. they clip into the two holes on either side of the radio and then you push outwards and pull on the clips at the same time and the radio slides right out. the tools are usually inexpensive and can probably be found at local auto parts store
Apr 07, 2009 | 2002 Ford Explorer
I need a wiring diagram for the stereo and eq of my 93 ford probe
Digital Audio Compact Disc Player
Section 15-01: Radio, Tape Chassis and Digital Audio Compact Disc Player 1996 Probe Workshop Manual
REMOVAL AND INSTALLATION Compact Disc Player, Digital Audio SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Radio Removing Tool T87P-19061-A
Removal
  1. Disconnect the battery ground cable (14301).
  1. Remove the instrument panel finish panel (044D70). Refer to Section 01-12 for the removal procedure.
  1. Insert the Radio Removing Tool T87P-19061-A into the face plate holes until the tension of the tool locking into place can be felt. (There are tension clips that this tool pushes out of the way so the radio can pull out. Maybe you can insert 4 pins that will do the same thing.)
  1. Flex outward on both sides of the radio chassis (18806) simultaneously and pull the radio chassis from the instrument panel (04320) using the tool as handles.
  1. Disconnect the electrical connectors and the radio antenna lead in cable (18812) from the radio chassis.
Mar 17, 2009 | 1993 Ford Probe
Manual
Here is the link to the manual for the cr560x which appears to be very similar - couldn't find the manual online for your exact model, sorry. http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13522&langId=-1 Hope this helps :)
Apr 11, 2007 | Jensen CR550X
Jensen CR-560X Cassette Player Logo
344 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
