Question about Alpine CDA-9884 Car CD/ MP3 Player
It wont turn on
My cda-9884 alpine radio wont turn on now that i have an amplifer and 2 subs even though power is being sent to it
  • 67 Answers
Check for a short on the speaker out wires or cut and tape them so they do not ground out
Posted on Apr 13, 2009
How do you change the time on the clock? Don't
This is from Page 7 of the manual available on Alpine's site:
moz-screenshot-1.pnghttp://vault.alpine-usa.com/products/documents/OM_CDA-9884.PDF
Setting the Time
1. Press and hold F/SETUP for at least 2 seconds to activate the SETUP selection mode.
2. Turn the Rotary Encoder to select CLOCK ADJUST,
and then press "magnifying glass"/ENT
3. Turn the Rotary Encoder to set hour.
4. Press "magnifying glass"/ENT
5. Repeat steps 3 and 4 above to set minute.
6. Press and hold F/SETUP for at least 2 seconds to return to normal mode.
I hope that helps.
May 21, 2010 | Alpine CDA-9885 CD Player
How do you setup the clock so that it shows all the time? How do you setup the bluetooth to an iphone?
ive had a good look round for you , and i have found a manual for you to download, this describes how to set the clock..mark.
http://www.retrevo.com/support/Alpine-CDA-9884-Car-Receivers-manual/id/23223ci369/t/2/
Mar 15, 2010 | Alpine CDA-9884 Car CD/ MP3 Player
Alpine CDA-9884 buttons do not work and sometime does not turn on
this will sound insane but it works; remove the radio remove the indicator panel (with the buttons) and, soak the buttons in rubbing alcoho then let dry for 24 hours,
you have drit in the unit holding the switches on
Sep 10, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Hooking up alpine hd radio unit, bt-400, which one do i hook ipod to
Niether .... do you know what you have in hand? Both those extras costed someone some cash ... OK here it is: the CDA-9884 has a dedicated input for ipod (a KCE-422i cable is needed and comes with the new CDA-9884 in the box) ... The HD radio unit allows you to recieve new HD radio signals (digital radio, and stations that have it in your area may also have extra music streams like HD TV does). The bt-400 is a bluetooth adapter to use bluetooth enabled devices with such as a cell phone. If your ipod has bluetooth you could used the bt adapter but I suggest the KCE-422i cable instead, and check out the HD radio too, it's pretty cool.
Apr 17, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Auxilary wont work on my alpine cda 9884
you need to go int he teupmode of the radio
turn off the cd changer option and turn on the aux mode
good luck
Jan 19, 2009 | Hifonics Eagle Car Audio Amplifier
My Alpine CDA-7863 does not read when I turn the ignition on,the screen does not read,it just make a clicking noise.I have no idea how to manually wire it .I just bought a 1996 tahoe and this Alpine was in...
1. you can go here and get a wiring manual with right model #.
http://www.alpine-usa.com/US-en/support/
2. The red wire goes to ignition switch/key.
Yellow wire goes to constant hot/battery.
Black wire is ground.
Blue wire is for power antana you do not need to hook that to anything.
You can look at this diagram for a little more help it is not your radio though but it will give you a reference point to look at. All radio red,yellow,blue,black wires are the same on all radios.
go to page 42 on this site for wire diagram.
Good luck with problem.
Dec 15, 2008 | Car Audio & Video
Alpine 9884 and ipod hook up
No. This unit is designed to choose songs through the deck itself
Oct 10, 2008 | Alpine CDA-9884 Car CD/ MP3 Player
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Alpine CDA-9884 Car CD/ MP3 Player Logo
183 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
