Question about SanDisk Sansa c140 MP3 Player
SanDisk sansa c140
When i connect my SanDisk sansa c140 1.0 GB with USB drive of computer its not recognised and also when i start my player the menu names are not displaying only empty white screen coming off
  • 1 more comment
  • seek_akshay Jul 09, 2008
    i also have the same problem When i connect my SanDisk sansa c140 1.0 GB with USB drive of computer
    not displaying only empty white screen coming off....if u have a solution than please tell me as soon as you can.....
  • anil burade Aug 17, 2013
    i also have the same problem when i connect my Sabdisk sansa c140 1.0 GB with USB DRIVE OF Computer its not recognised ans also when i start my player the menu name not displaying only empty white screen pl have a soulution as soon as possiable
    my mail id is anil.burade@gmail.com
  • 626 Answers
You need to Have Windows XP / SP2, Wndows Media Player 10 or higher in order for the device to be recognized. If you have these components, try changing the mode on the device to MSC Mode. Settings>Mode>MSC. Best of Luck.
Posted on Sep 12, 2007
My computer is not recognising my sansa 4.0.gb
You should make recovery mode on your player then make firmware upgrade.
The recovery mode:
1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off.
2. Slide the Hold switch so the orange portion shows.
3. On your PC, double-click My Computer
4. On your Sansa player, press and hold the REC button while connecting it to the PC.
5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer.
If this work, this link helps you to upgrade:
http://kb.sandisk.com/app/answers/detail/a_id/306
I hope I could help.
Feb 11, 2011 | SanDisk Sansa e260 MP3 Player
My computer doesn't recognise my sansa 260.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard ths should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
How do you take music off your mp3 player
The Sansa c140 can be operated in MSC and MTP mode for transferring and deleting music files.
See also setting USB mode for autodetect or MSC mode on page 16 of the manual: link to the Sansa c100 series manual.
  • For deleting files a connection to a computer has to be made in either MSC or MTP mode, see page 10 of the manual.
MSC mode means that a computer will see the player as a removable disk when connected.
It's like exploring the computer detecting the player as an external memory, showing up as a drive letter with about 1 GB of memory.
Before disconnecting the player, always safely remove hardware, the icon in the bottom taskbar on the right.
MTP mode means that a computer has software installed like Windows Media Player 10 and in this software, when started, the player is being recognized as Sansa c140.
Before disconnecting the player, wait for the message that it is allowed to disconnect the device.
How to use Windows Media Player 10 ? See the site of Microsoft:
http://www.microsoft.com/windows/windowsmedia/player/10/using.aspx
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa c140 MP3 Player
Sansa c140 SanDisk
I had the same problem, first on the mp3 player under settings change the USB setting to MSC. Then plug the mp3 player back into the computer. Open the My Computer icon, right click on the SANSA C140 icon and click format. Make sure it's Fat32 and Quick Format is Not selected. Then click format. This will take a few minutes. When it's done your mp3 player will be just like a usb drive; you're files will be read normally.
* if it's a voice recording you're trying to find, look under music and scroll down to Recordings. If it's not there then perform the above format.
Also it only reads mp3s and pictures (gifs, jpgs). Unfortunately the c140 doesn't play videos :(
Dec 23, 2007 | SanDisk Sansa c140 MP3 Player
Sandisk c140 display problem
I have a quick and painless solution for you.
First open your mp3 player and go to settings. Under the USB menu change it to MSC. Then plug in the mp3 player to the computer. Open the My Computer on your desktop, right click on the Sansa mp3 player and click Format. Make sure Fat32 is checked and Quick format is UNchecked. Then format the mp3 player. After that it should be clean and work just like a USB drive.
Hope this helps!
Dec 10, 2007 | SanDisk Sansa c140 MP3 Player
Sync problem
Hope this helps!
Aug 24, 2007 | SanDisk Sansa c140 MP3 Player
Fixing my C140 (has no lettering on screen)
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
Jun 01, 2007 | SanDisk Sansa c140 MP3 Player
Recognise my sansa
to old for vista to recognize
Apr 29, 2007 | SanDisk Sansa m240 MP3 Player
Synchroniz
Hope this helps!
Jan 26, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa c140 MP3 Player Logo
94 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
