Question about Whirlpool Dryers
Outlet wired wrong, nothing works
I have a whirlpool front load dryer. I plugged in the dryer to the out let and heard some humming, then a click, then nothing. The lights do not come on, nothing. I opened up the outlet and saw the wires were incorrect according to the panel on the back of the dryer. The white (neutral) was not on the center of a 3 way recepticle like it should have been. Is there a reset, or did I burn something up?
  • 2 more comments
  • andymcfar Apr 13, 2009
    it had a black wire on it. Model # GEW 9250 PL
    Nothing works now.........
    Thanks for the help, I hope that is the problem. I can replace it myself can't I?
  • Scott Wiuff
    Scott Wiuff May 11, 2010
    was there the black or red going to the center? If there was it probably did fry something. There is not really a re-set on them either. What is the model number on there from in the front door?
    Scholar:
  • 87 Answers
Ouch! That would of applied 220 to the controller. Do any lights come on or can you get it to do anything now that it's wired right?
Posted on Apr 13, 2009
  • Scott Wiuff
    Scott Wiuff Apr 13, 2009
    it's most likely the user interface p/n
    8558753 (item 19) ON THE LINK BELOW. about $160.00 bucks but that's about all it could be. Sorry I couldn't be much more help or cheaper. Good luck.
    http://www.searspartsdirect.com/partsdir...
  • Scott Wiuff
    It should be pretty easy to replace. There are 3 screws to take off the top cover then you should be able to see what you need to get at to remove.
    Sergeant:
    Champion:
  • 396 Answers
Did you get the wiring of the outlet checked out? Did the breaker for the outlet trip? In some cases there are safety systems built into appliances. Not all but some. This may consist of a fuse. Not the same as your car but works the same.
I would get a serviceman out there to look at it. And an electrician to verify the wiring.
One last note here. Sometimes when a wire is loose but not disconnected and it gets a little power through it, it will short out. Can cause all sorts of strange happenings.
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
Dryer sometimes works and sometimes doesn't, what's the problem?
i have a feeling that it's a fault in the power chord, take it out and double check. it would make sense if it only work now and then after you have plugged it back in because it could have made the wires touch again to make it work
Jun 29, 2014 | Whirlpool Washing Machines
Seems like my dryer is getting no power. No
Good day,
The most common problem is the door switch. followed by the push to start switch.
You would need a VOM meter to test both.
If both check O.K. then it would have to be the timer or the motor itself.
I would move the plug to an outlet that is currently powering another device just to be sure.
Short of that it could be a broken wire starting with the cord itself.
Here's a tutorial of how to tear the machine down.
http://www.applianceaid.com/wpmotor-change.html
Apr 14, 2010 | Whirlpool Dryers
Front door is locked and I cannot restart machine. Indicator light says "f d/l". How do I unlock the door?
Disconnect the machine from the outlet. Prop up the lower front edge of the machine with a block of wood or cushion the top rear edge with cloth and lean it against the wall. Remove the three screws securing the lower toe panel to the cabinet and pull it down then out.
Reach up and locate the bottom of the door latch assembly along the inside of the front panel. Gently pull down the manual door unlocking tab until a click is heard. Open the door when the click is heard.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer gew9250plo dryer will not turn on
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram heaver red wire for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Why won't my dryer turn on?
you eather have a broke door switch or a blown thermal fuse you can check the door sitch just press and releace the switch it sould click it the tab i not broken if it is broken or you don't hear it click just replace the door switch.if the switch is good you need to replace the thermal fuse it is located on the back of the dryer. unplug the dryer remove the back cover at the bottom the is a small white fuse on the blower housing it has two blue wires pluged into it remove the one screw and wires replse the fuse reconect wires put back cover on plug in dryer and test.
Jan 20, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet Dryer stopped working
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Dec 27, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
73 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
