Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
NEW WHEELS AND BRAKE ADJUSTMENT MOWER WILL NOT MOVE IN ANY GEAR
17.5 HORSE 42" LAWN TRACTOR MODEL 917.272673 INSTALLED 2 NEW REAR TIRES AND ADJUSTED BRAKES THE PROBLEM IS THERE IS NOFORWARD OR REVERSE PULL IN ANY GEAR. IF I RAISE THE REAR END OFF THE GROUND THE TIRES SPIN IN ALL GEARS BUT I CAN STOP THEM WITH LIGHT PRESSURE FROM MY HAND. BEFORE WHEEL AND BRAKE SERVICE I HAD NO PROBLEM WITH IT.
    Sniper:
  • 79 Answers
Is it a hydrostatic drive and did you pull the pin that is located by the hitch. The pin should be pushed in in order to engage hydrostatic drive.
Posted on Apr 13, 2009
If the gear power become low what will be solution
Posted on May 27, 2012
My 12 year old pouan riding mower model 287707 when foot brake is pressed mower wont stop
If you look around the rear axle you should see a half moon shape shoe that is the brake and there should be a rod coming off of that to adjust the brake.
May 20, 2014 | Poulan Garden
I have a Craftsman mower 917.280810.It barely moves when clutch is released,even on flat ground.I changed the belt-no help.The transaxle pulley is engaged,and when I put my hand on the tire,the tire stops...
I don't quite get you, if the belt is running but the rear axle is not turning then your transmission is shot. If the belt is running and the rear axle is spinning with no forward or backward motion, then someone took the back wheels off and put them back on without installing the keyways.
Sep 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Problem shifting
If the shifting is easy when the engine is off you have an adjustment to make on the clutching mechanism. if you loosen the belt (the adjustment is under the mower) it should improve the shifting but do not loosen it too much to where the belt begins to slip when in drive.
Jun 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you adjust brakes on a 30 inch murray,model 30550A lawn tractor.
Sit on mower find the right rear wheel,put your mowers deck in the lowest position.
look under the mower between the rear of the deck and right rear wheel you will see the transmission and a small disc (looks like a small brake rotor) there is a nut on the outside of that disc and or close to that disc 9/16 or 1/2 inch standard wrench size,turning that nut clockwise tightens the brakes ccw loosens.
May 09, 2010 | Garden
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My mower brakes do not work
The adjuster is on the right side just in front of the rear wheel. its the clutch rod / brake rod . you will see a spring on the shaft with two nuts one used to lock the adjustment. loosen the nuts and turn the nuts so the nuts go towards the back of the tractor. keep checking the peddle for brake .
Sep 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman model # 917271652 will not drive. I think the rear end is out
check the drive belt and pullys ,, also try pushing mower out of gear and in gear to see what you have,, make sure the brake not on,, hope this help you,, good luck
Aug 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20HP , can't stop freewheeling,
Sounds like your problem is the key in your rear wheel is missing or sheared, you have to remove the wheel @ tire assembly ,pull rubber cap off then clip to remove if one of the keys is sheared or gone it will go into gear and the brake will work ,but they will only stop the shaft without the key it will not move or brake becuase its not attached if you know what I mean.
May 11, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Clutch/Brake Pedal Problem
first off your biggest problem is its built by MTD.they build about 90% of the riding lawn mowers you see in the stores that are 20 horse and under,every thing from a yard machine to a craftsman to a cub cadet. you need to get under it and fallow the linkage from your pedal to your rear transaxle. that link is adjustable if it is not , then the arm it attaches to is .you need to adjust it whichever way takes slack out of the belt, if all the adjustment is out then replace the belt and adjust it accordingly
Apr 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Frozen won't budge
On lawn tractors, usually on the right rear wheel, there is a brake for the transmission, if the brake seizes up, the mower will not move...the size nut on the brake adjust is 1/2 inch, all it takes is about 1/2 turn on the nut and the brake should release the disk
Apr 24, 2009 | Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
416 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
