Question about Adobe Photoshop CS2 for PC
About create a moving any object
I didnot tack any steps
  • 49 Answers
Not sure I understand. If you wish to create animated gif or png files you would use ImageReady or Macromedia Fireworks
Posted on Sep 12, 2007
SOURCE:
Do you think its safe to use clear wall tacks in a pre school class? Isn't Scotch Tape safer on walls not made for tacks?
I would never use tacks or any type of sharp object in a preschool classroom. There are so many other ways to mount things that make more sense. For instance, many white boards are magnetic and you can use large magnets (avoid small ones which could be swallowed) and 3M makes dozens of mounting products that are clear, don't ruin wall surfaces, and are non toxic should a child decide they want to put one in their mouth. As a general rule if you can take an object, poke yourself with it, and bleed, it shouldn't be in a preschool classroom.
By the way, Scotch tape is not a good choice for sticking things to walls. In many cases, it's not strong enough to adhere to the wall, and if it's a painted wall, it will take the paint off the wall.
Jan 04, 2017 | Preschool
Easiest way to make a buttonhole...manual does not tell much info
Easiest way is to create a bar tack at one end of the buttonhole (widest stitch width and stitch length set to 0). Stitch maybe 4 or 5 stitches.
Then move needle all the way to the left, set stitch length to very short (maybe somewhere between 0 & 1), width to slightly less than half, stitch forward to the end of the buttonhole.
Then make another bar tack (as above). Move needle all the way to the right, set to less than half width, short stitch length, and stitch in REVERSE to first bar tack. To tie off, set width to 0 and length to 0 and stitch 2-3 times in place. Raise presser foot, pull gently on fabric and clip threads.
Mar 12, 2015 | Sewing Machines
How to make a butten hol
This is a 4 step process. You start at the first step and it sews backwards first, Next you perform step 2 to sew the bar tack. Third you sew the right side of the button hole as it comes towards you. The final step is another bar tack which is the same as the second step.
Dec 26, 2013 | Husqvarna Huskystar 215 Sewing Machine
How verify my yahoo password
Step 1:
forget passward
Step 2:
not sign in
wrong passward
Step 3:
Ididnot remmber the answer of secret question
i didnot remmber alternative email
Step 4:
i didnot now what to do
Mar 29, 2013 | Yahoo Mail
My machine has a one Step Buttonhole Feature - having problems
Try an Even Feed Walking Foot for more control on thick and quilted type layers
Dec 10, 2011 | Brother CS6000i Computerized Sewing...
It says tacke away papper from huvud fack in swedish. its no papper wher they come if it prints att it shuld. whats the mater it maks mi nervus . cant print enything its stuck one this error message!?...
You have not cleared the entire media path, or you didnot open the door specified by the message to check for jams in this area.Please clear media from the entire path, open the door indicated by theoperator panel message, clear the jam, and close the door and the printer resumesprinting. For further assistance, please contact LexmarkTechnical Support.
Jun 16, 2011 | Lexmark C510 Laser Printer
Have a f02 code on washer what does this mean
Its already answered by an expert :-
When this code appears, you want to clean out the filter and check the pump. No matter how diligent we are in checking pockets and whatnot, invariably objects end up in the washer. Things like coins, nails, pencils/pens, and other hard objects. Sometimes these objects or pieces of these objects, can make it to the pump and can clog or damage it. I would take a flashlight and look into the suction port of the pump. Look for anything clogging the pump and check out the impeller blades. Make sure none are missing or damaged and that the impeller will move freely. If any of the blades are missing or damaged or if the impeller won't turn freely, then the pump will have to be replaced. Hopefully the pump is only clogged.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Every time i take a picture of a moving subject on my fuji s3000 digital camera the subject i have just took does not appear on the frame.or only partly in the frame i have tried on all modes even the...
try this photography technique called panning...
panning is when your shooting a moving object you need to follow that moving object while pressing shutter speed..this technique is the technique photographers to capture moving objects...Have you seen a picture that has a blurry background and focused subject (ex. cyclist) panning is used to create this kinds of pictures...try to search in google or photo sites about Panning
Jul 06, 2009 | Fuji FinePix S3000 Digital Camera
Failed to Create print object
Step 1: Click Start --> Printer and Faxes --> Add a printer.
moz-screenshot.jpgStep 2: While wizard appear, click next and tick on A network printer or a printer attached to another computer. Click next.
Step 3: On the specify printer options, tick Connect to a printer to the Internet or on a home or office network. Specify your printer destination. Example: http://192.168.110.120/
Jan 30, 2009 | Lexmark X945E Printer
Cannot insert columns in excel spreadsheet. Comes up with error cannot shift object off sheet
This error message occurs if the following conditions are true:
  • The option Nothing (hide objects) is selected in the Display options for this workbook section in the Excel Options dialog box.
  • You create an object, such as a cell comment, in any cell in a column.
  • You try to hide the column to the left of the column that contains the object, the column that contains the object, or all the columns to the right side of the column that contains the object. Or, in some cases, you try to insert a row or column in the worksheet.
There are two ways to fix this problem.
Method 1:  Temporarily toggle the option from "Nothing (hide objects)" to All In Excel 2007, temporarily toggle the option from Nothing (hide objects) to All, and then insert the rows or columns as needed. To do this, follow these steps:
  1. In the upper-left corner of the Excel window, click the Microsoft Office button.
  2. At the bottom of the menu, click Excel Options.
  3. Click Advanced from list of options on the left.
  4. Scroll down to the Display options for this workbook section, and then click All under For objects, show:, and then click OK.
Notes To use the keyboard shortcut to toggle this selection, press CTRL+6.
If these steps do not let you hide rows or columns or insert rows or columns in Excel 2007, try the steps in method 2.
Method 2: Change the position property of the object to Move and size with cells To work around this issue, Excel 2003, Excel 2002, and Excel 2000, change the position property of the object to Move and size with cells. To do this, follow these steps:
  1. If the object is a cell comment, select the cell that contains the comment, right-click the cell, and then click Show Comment or Show/Hide Comments. Note This makes the comment visible.
  2. Move the pointer to the edge of the object until the pointer changes into a white arrow with four small black arrows on the pointer. Then, click the object to select it.
  3. In Excel 2003 and earlier version of Excel, click <object name> on the Format menu. Note In this menu command, <object name> is the name of the object, such as "Comment" or "AutoShape."  In Excel 2007, click Format <object name>.
  4. In the Format dialog box, click the Properties tab.
  5. Click Move and size with cells, and then click OK.
  6. If you want to hide the cell comment again, right-click the cell that contains the comment, and then click Hide Comment.
  7. Follow these steps for each object in the affected column as described in the "Cause" section. When you hide the columns, you do not receive the error message.
For more information, visit the Microsoft Knowledge Base article: http://support.microsoft.com/kb/211769
Nov 06, 2008 | Computers & Internet
Adobe Photoshop CS2 for PC Logo
62 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
Ekse
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
