Question about HP Officejet 5610 All-In-One InkJet Printer
Cannot print from hp5600 all in one. - HP Officejet 5610 All-In-One InkJet Printer
  • morain29 Apr 14, 2009
    When I print a test page everything is fine, but when I try to receive a fax there is nothing but a blank piece of paper.
My HP 5600 will not print
Posted on May 21, 2009
1) we will check that printer is start or pause.
2) If first condition is correct,then OPC drum is filled or not.
3)If both conditions are right, then there should be Hardware problem .
Posted on Apr 13, 2009
My HP5600 printer had a paper jam which I cleared. The printer still indicates a jam and I cannot get it to print.
try shutting it off and remove all cables connected with the printer. wait for a few minutes and connect all cables back and then switch on the printer. meanwhile, also shutdown your PC and turn it on again too. now try printing, it should work fine.
hope it helps.
Feb 18, 2011 | HP Officejet 5600 series
Hp5610 all-in-one
see it this site your problem solved
http://cluetechnologies.com/index.php?topic=688.0
Jul 03, 2010 | HP Officejet 5610 All-In-One InkJet...
HP5600 print cartridge- error- message
Insert the correct CD
Windows Users:
a Insert the gray HP All-in-
One Macintosh CD.
b Continue to the next page.
a Insert the green HP All-in-One
Windows CD.
b Follow the onscreen
instructions to install the
software.
c On the Connection Type
screen, make sure to select
directly to this computer .
Note : If the startup screen does not appear after you
insert the CD, double-click My Computer , doubleclick
the CD-ROM icon, and then double-click
setup.exe .
Jul 01, 2010 | HP Officejet 5610 All-In-One InkJet...
I can't print a pdf file with officejet hp5600
hi,
please check if the print spool service is working or not.( start - run - services.msc)
Sep 27, 2009 | HP Officejet 5610 All-In-One InkJet...
I lost the installation disc for my hp5600 how do I install without it
Go to this link and select the correct print device that you have. Download and install the device driver. You should be able to follow the onscreen instructions for installation.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=hp5600
Jul 07, 2009 | HP DeskJet F380 All-In-One Printer
Wrong ink cartridge jammed in HP5600 series printer
With printer OFF:
Open the back door and rotate the main wheels until the cartdrige carrier unlocks.
Open the main cover, and slide the cartdrige until you reach it good enough.
The rest, nobody can help via interntet, i'm sorry, it just takes skill and patience to kill it out.
Take care not to cut or damage the connectors.
Dec 04, 2008 | HP Officejet 5610 All-In-One InkJet...
Can't print from my computer.
I can understand your frustration, but do not panic.
First Go to Start> Control panel> Printers and faxes> And in the HP 5600 series check to see what the icon say...? (Does it say 0Ready or does it have and jobs in Que)
Right click on the icon and left click on Cancel all documents ( until it says 0Ready)
Make sure the HP 5600 series is set as a default printer.
Then go to Start> Run> under run type in services.msc and hit Ok and in the services window locate for print spooler and under service status you should see a tab which says stop highlighted click on the same (a window will pop up and close), now you will see start highlighted click start and you will see the same window pop up and close,
Now stop should be highlighted, click on Apply or Ok and restart your computer.
Then after restarting your PC go to Start> Control panel> Printer and faxes> and check where the check mark is in and the default printer should say 0Ready.
No right click on the default icon and left click on properties. and under properties to the bottom you will see a tab which says print test page.
Click on it and see if it prints a test page.
And then if it prints try printing from any application.
Good Luck
Sep 18, 2008 | Office Equipment & Supplies
HP5600
You would need to go to your control panel, then printers, then right click on the HP5610 and then properties. Once there, you would need to look for the color setup screen. You should be able to choose something similar to: "print colors in black & white only". That is the only thing you can possibly change to force black & white printing. However, not every printer has this feature.
Jun 20, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
211 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
