Question about Hampton Bay 24750 Huntington III Ceiling Fan
Hampton bay CFL lights flicker when they are turned off
I have a remote on the fan. When I turn the lights off, the CFL still flickers. any ideas.
  • Gijera May 02, 2009
    I Have a Hampton Bay Fan Light from Home Depot and the new CFL light bulb's that I put in will flicker when I turn them off with the remote control. Although if I turn off the light switch after I turn them off with the remote control, then they do not flicker.
  • 323 Answers
I believe the flickering comes from the way the CFLs extinguish themselves after the remote turns them off. As the other poster said, turning them off with the wall switch as well after turning them off with the remote stops the flickering.
It is because the remotes are a dual mesh type of signal, which uses the RF as well as the electrical power to activate and turn them off.
Actually, this type bulb is not designed to work as well in dimmers or remote switches as is incandescent. You will find if you replace them with regular incandescent they will not flicker.
Sirwriter
Posted on May 26, 2009
You cant use a CFL in a remote operated fan. The starters built into the bulbs still pick up power when they are switched off at the remote. They act more like a dimmer swich and not a true off switch. The bulb will act like its a drop in current and fire its starter off over and over attempting to restart. Thats the flicker you see at night.
If you search you may be able to find a CFL that is made to work with a dimmer switch, or you can use a LED bulb or even a standard bulb to prevent this.
Posted on Oct 21, 2012
The back of my Turn of the Century fan's remote control has this switch in the back of the battery housing. It's marked with 'D' and 'CFL' on either end. Can someone tell me what this switch means?
The switch is allows you to tell the remote which type of light bulb you have installed in the fixture. The CFL setting is for the included compact fluorescent bulbs. With these bulbs, you can only turn them on and off. If you put in incandescent bulbs, set the remote to D. Then you can dim the lights in the ceiling fan, in addition to turning them on and off with the remote. CFL bulbs can't be dimmed with this fixture.
I found this described in the manual for the Turn of the Century Midori 52" ceiling fan. This fan is available at Menards: https://www.menards.com/main/lighting-ceiling-fans/ceiling-fans/indoor-ceiling-fans/turn-of-the-century-reg-midori-52-contemporary-ceiling-fan/20338/p-1444433460319.htm . The direct link to the manual is currently https://hw.menardc.com/main/items/media/HONGK003/Install_Instruct/3551058-3551059_install.pdf .
I hope this helps.
Apr 01, 2018 | Dryers
Light flickers dimly when turned n
Make sure you have the correct wattage in the bulbs. If you have a remote, make sure it's set for non-dimming feature if you have CFL bulbs.
Feb 19, 2015 | Hampton Bay Dryers
Kendal fan/light remote UC7208T doesn't dim
If you have CFL bulbs they won't dim. There should be a switch to change remote from CFL to incandesant light inside the transmitter. You'll have to match settings with settings in receiver.
Nov 25, 2013 | Dryers
Ceiling fan lights flicker in bedroom with 23watt cfl bulbs
Sounds like an older unit that has either a dimmer or electronic switch. You need to use dimmable CFL lamps.
Nov 07, 2013 | Hunter Dryers
Hampton Bay 52-ANT
If you have a ceiling fan, they often suffer remote operation failure as a result of a power interruption. Try disconnecting the power source. Leave the local switches and chains alone. After a brief pause, apply source power again and try remote operation
Jun 28, 2013 | Hampton Bay Dryers
Contempo ceiling fan with light no remote or dimmerr
If it's a medium base CFL bulb then you can try a regular medium base bulb. What is the make/model of fan that you have?
May 12, 2013 | Dryers
Compact fluorescent flickers when the switch is off.
You could be getting power from the source in the switch ... does this flickering occur with a non illuminated switch? Have you tried the CFL in other sockets? Have you checked the socket in question for proper polarity? (Hot wire should be broken by the switch and that hot wire should be connected the bottom of the CFL in the socket). Does your switch have a white wire for the neutral connection or are you using the ground wire to illuminate the switch ... or is there a different lind of light in the switch and/or do you know?
Normally ... let me say again ... normally, (in a traditional sense) an illuminated switch should have a neutral connection, a ground lug and the expected 'in' and 'out' for the switch leg. Normally, I would expect the switch leg to use a black from the power source (normally found in the box where the socket is mounted) and a white from the 'off' side of the switch to the socket.
I tried to draw you a diagram ... but it didnt work out and you probably already get the picture.
If everything checks out ... and it still flickers, replace the switch with a non-illuminated switch or use a incadescent light until they are no longer available.
Thanks for your interest in FixYa.com
Jun 21, 2010 | Cooper Lighting Lighted Switch
I have a hampton bay ceiling fan. I put cfl bulbs in the lights and when i turn the lights off using the remote the bulbs continue to flicker. when i turn the wall switch off the bulbs stop flickering. the...
The problem is that the CFL lamps, once they are lit, will stay energized by a very low level of current, and the remote obviously is not what we would call a positive off device .. if you use the wall switch and then go back to the remote in the off position , do the lights come on flickering again? You could try another brand of remote.
May 19, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
1,390 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
