Question about Toshiba TDP-T30U Multimedia Projector
I actually have the TDP-S26, but looks similar
I have enjoyed my projector for a few years now, but when I turned it on the other day, the VGA input didn't recognize the signal from my computer! I tried different cables and different computers with no success. I plugged in my VCR into the composite input and it works just fine. Therefore, I know that the projector is working, it's just not "seeing" any signals that come in through the VGA! Any ideas??
  • 1 more comment
  • Anonymous Nov 08, 2007
    TDP-D1 (handmedown). My Toshiba laptop's f5 seems that it isn't programmed to do function-f5 to toggle between options. note in the case says use f8, which does not work either.
  • Anonymous Dec 26, 2007
    neither of my vga inputs work....they don't recognize anything....first the vga 1 went out then the vga 2 went out???????????
  • hennessey May 11, 2010
    My projector only displays in black and white. There is only 364 hrs on the lamp
SOURCE:
  • 17 Answers
SOURCE: Sharper Imaage
This is an SVGA projector with a max resolution of 800X600. Even though it can accept higher resolution signals, they are scaled down to 800X600 which causes degradation and artifacting of the displayed image. Obviously setting your computer's resolution to 800X600 will result in the best image the projector is capable of. Standard definition video (480i, 480p, S-Video or composite) signals should also display very well. High definition signals like 720p and 1080i get scaled down to 800X600 with the same issues as a higher resolution computer signal.
One thing that can have a dramatic impact on the quality of your display if you are using Windows XP or Vista is tuning your ClearType settings here:
http://www.microsoft.com/typography/ClearType/tuner/tune.aspx
Posted on Jan 17, 2008
marsrover
  • 682 Answers
SOURCE: toshiba projector tdp-s8
please start your computer first and then the projector- use function key with f4 or f6 or f7 or f5-and select computer from input of the projector.
Posted on Mar 21, 2008
SOURCE: How do I check the bulb hours on a TOSHIBA TDP-S26 PROJECTOR?
I found a similar issue with another brand/type of projector and used that solution. It worked!
Posted on Mar 24, 2009
RadarRon
  • 398 Answers
SOURCE: connected VGA cable to my pc and projector.Searching only
First off be sure that you plug into the input connector. As you look at the back of the projector it the VGA connector on the left. Also make sure you activate the VGA output of you computer (This mainly applies to laptops and secondary Video jacks on PCs).
Posted on Jan 15, 2010
SOURCE: toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Posted on Jul 22, 2010
How do you reset lamp hours on a Toshiba TDP-Tw420 projector?
1. Turn-off the projector by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
Jul 31, 2011 | Toshiba TDP-TW420 DLP Projector
I have connected my toshiba TDP-T9 to my laptop but I'm getting a "No Signal" error on screen. Could my VGA cord cause this?
Depending on your laptop, the internal splitter may be turned of. Usually the keystroke to turn it on is Fn F8. However it may be different on your laptop. Look at the function buttons, and the one with a screen looking thing on it is the one you press with your "Fn" key.
Jan 27, 2011 | Toshiba TDP-T9 DLP Projector
Cannot get connected to notebook pc
The most common problem is compatability of VGA signals.
Check the input settings and the notebook settings, they must be the same otherwise the projector will ignore the PC.
Hope that helps.
Nov 27, 2010 | Toshiba TDP-S25U Multimedia Projector
Mar 23, 2009 | Toshiba TDP-T30U Multimedia Projector
Projector will not read feed from laptop
hi
is this an optoma make , then yes it is amain board problem & it can be repaired.do let me know the model no
Feb 12, 2009 | Toshiba TDP-S8 Multimedia Projector
Colors look smeared on screen
If the colour wheel on your projector is out of sync, you will get incorrect colours.
If it is out of focus, focus the lens assembly, if misaligned colours, perform a re-convergence procedure at a fully equipped work shop with a qualified Toshiba engineer.
Oct 31, 2017 | Toshiba TDP-T30U Multimedia Projector
Connecting a Sharp Multimedia Projector XR-40/30 Series Notevision 30X to a HP Pavilion Zd7000. I cannot get an imageMultimedia projector
use a vga to vga cable. if your HP has a 13 pin serial conector. (looks like a trapezoid), use that.
If not you may need a dvi to vga cable.
if not, the projector may have two ports on the back - use computer in - not monitor in.
Lastly, try the video settings on the HP to see if its picking up the projector as a second monitor as a primary
Makes a difference, NGK
Aug 07, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP T 91A
Hi there
I would suggest you investigate it yourself first before dishing out that sort of amounts.
Check if the fans are running.
Most of the times the overheating of a Projector is as a result of a faulty fan.
Mar 26, 2008 | Toshiba TDP-T91AU Multimedia Projector
Sharper Imaage
Jan 17, 2008 | Toshiba TDP-T30U Multimedia Projector
Toshiba projector tdp-s8
Dec 29, 2007 | Toshiba TDP-S8U Multimedia Projector
Toshiba TDP-T30U Multimedia Projector Logo
197 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
