posted by narx71987 on Sep 11, 2007
i have two ppi power class pc2150 amps that i bought on ebay..both the security stickers are intact..one amp "bumps" anytime you change tracks or start the stereo or push any buttons on the amp also when u adjust the gain it continuously moves the woofer with the turning of the knob...the other has none of these symptoms..any help would be great!!thanks!!
Solution #1
posted on Sep 16, 2007
There are several resistors that open or change value in these amplifiers if the speaker wires are allowed to short to ground. There are generally two 10 ohm resistors near the RCA jacks. These are the most likely source of the problem.
If you haven't tried it yet, swap the signal lines from one amp to the other to see of the problem follows the signal line or remains with one amp.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Jensen A300HLX Car Audio Amplifier
Jensen A400HLX Car Audio Amplifier
Dual 2-Channel Bridgeable MOSFET Amplifier (XPA4100) Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-859 Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-929 Car Audio Amplifier
Can you Help with these Car Amplifiers problems?
Scosche Industries EFX Amplifier Wiring Kit...
1995 stony creek popup by
1995 stony creek popup by... Answer This...
MA Audio HK4000D Car Audio Amplifier
ok last shot thn i think i got...
my cap was on wrong and i had... Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
