Question about Vanguard International Vanguard BY Rheem G91-200LP Gas Water Heater
Pilot won't light on Rheem Fury G 29-30
I removed the door below and see a hole that goes to the gas line....I assume this is where I light it?  I turned the nob to pilot and push the red button down and stick a lighter up in the hole and get nothing.  Is this the correct spot to light it.  There is not Piezo on this unit.
  • fergieclimbs Apr 13, 2009
    The hole I was trying to light it at where the large diameter tubing comes down was not the pilot light.  The smaller copper tubing that runs above it is where the pilot light is!  Once I located it...it lit no problem.  Rheem doesn't seem to have pictures of older units without the piezo for folks to reference.  I didn't need to purchase a thing!
  • 659 Answers
Your thermocouple is bad, that's why it won't stay lit. But you are in the right place. The thermocouple is located right in front of the pilot burner. It generaly pulls out and then you follow the copper tubing back to the valve, unscrew the fitting and it will pull out. Go to your local hardware store and purchase one about the same length and install it back in the same order. Good luck.
Posted on Apr 13, 2009
Rheem gas water heater pilot light went out when i tried to relight it does not light up again.
Usually if they won't re-light it's a problem with the orifice on the pilot itself. The thermocouple won't cause it to re-light but it will prevent it from staying on after being lit. Just make sure you have valve set to pilot when you press the red button down to light. You can take out the burner by removing the gas and thermocouple lines, unscrew the orifice and use like a wire brush bristle to clean out the hole in the orifice.
Aug 02, 2017 | Rheem Water Heaters
How do i re start the pilot lght
You will need:
a wire hanger or something like that about 14 in long
a small clip and matches to clip to wire.
Turn red knob to off
remove small door covers (Both).
look inside you will see a tube pointing up this is where you put the match to light it.
turn red knob to pilot and push down and hold
light match and put it at end of the tube inside it will light a blue flame
remove match.
all this time holding knob pushed down
continue to hold down for 60 sec
then let it up slowly and turn knob to on
should flame up and start whole burner
replace door your done.
OR call your gas company most will light it for free
Jan 17, 2016 | Water Heaters
Where is the pilot light for my hot water heater?
usually toward the bottom front of the unit .look where the gas line comes to it .
Oct 03, 2015 | Water Water Heaters
Rheem water heater pilot lite stays lit, burner goes out
Tripped FV or TRD, or bad gas control valve, low gas pressure, air in gas line.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Unfortunately, Rheem does not post service manuals. Other companies post service manual, but only Rheem uses TRD FV system, while other companies use arrestor screen.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
Add a comment and say what you discover.
May 24, 2013 | Rheem 42V75F Fury Heavy Duty Natural Gas...
We have an atwood lp gas water heater 6 gallon g6a7 white rogers control. The pilot lights but when we turn it to on it goes out, even after holding it up to a minute. It was running fine, we thought we...
If pilot stay lit, then thermocouple is working.
If pilot will light, then you have gas. If pilot goes out when pilot button is released, then thermocouple is next suspect.
Thermocouple tip must sit in pilot flame.
The pilot light heat applied to two different metals inside thermocouple causes small current.
The current travels back to gas control valve through copper line.
If the gas valve receive this current, then a magnetic switch stays open and allows gas into the gas control valve.
The magnetic switch is on the end of the red button you push down when lighting pilot. Essentially the red button is an override to the magnetic switch.
If the gas control valve does not receive the current, then the magnetic switch does not stay open when you release the red button.
When replacing thermocouple, note that it is not screwed very tight into the gas control valve. Finger tight + 1/4 turn. If it is overtightened, then the small thermocouple current shorts out against the gas control body.
Sep 01, 2012 | Water Heaters
Pilot light on hot water heater is out
you need to shut off the the red nob and turn the nob off in front take the cover off remove the heat shield turn the nob on top to pilot use a piece of paper to light put in next to pilot and hold button down for 20 to 50 secs pilot should stay lit turn nob on front then burner should kick on then you should be all good
Mar 21, 2012 | Water Heaters
I have a rheem fury model 21v30s and the pilot will light and heat the water but once the burner plate goes out the pilot goes out as well. How do I fix this issue without replacing the water heater? I...
Open a nearby window to let in plenty of air and see if problem continues.
Problem might be something simple like vent backflow blowing out pilot, or more complicated like bad gas control, or combination of problems listed below.
Suspects include:
Faulty gas control thermostat.
Air in gas line.
Low gas pressure.
Hot attic air.
Insufficient air, or dirty air intake.
Dirty combustion parts, and tubes.
Thermocouple not sitting in flame.
Thermocouple tightened too much. Finger tight + 1/4 turn. No joint compound or teflon tape.
Bad venting.
Backflow of air down vent pipe caused by tight house and/or other vent fans in house.
Open following link for resources, illustrations and reading:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 23, 2011 | Water Heaters
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Can't get the pilot light to start
Is this the newer style with closed combustion chamber. If so I would check to make sure that spark ignitor is working. If not it will need replaced. If ignitor is workingthen loosen compression nut on line to pilot and temporarily depress button on gas valve to make sure you have gas at that point.If you have gas there and tighten compression nut to pilot back up and it still won't light then you will need to remove screws that hold cover on burner compartment.Shut off valve to gas supply and remove gas line from gas valve remove pilot and thermocouple lines. Slide burner out ofcompartment and clean it .Remove nut from bottom of pilot assembly and clean out pilot orifice. Blow through pilot line to make sure it's all clear
Reassemble everthing using teflon tape or pipe joint compound as needed.Turn gas supply valve on and check for leaks.Set gas valve control to pilot and depress pilot button and hold. While you are holding button done push spark ignitor every few seconds until it lights. thank you and good luck
Dec 22, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Vanguard International Vanguard BY Rheem G91-200LP Gas Water Heater Logo
844 people viewed this question
Top Vanguard International Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Vanguard International Water Heater Expert? Answer questions, earn points and help others
