I turn on the A/C to my 2005 Honda Odyssey. It blows cold air, but when I hit the "rear" A/c button, the A/c blows HOT air from the front and rear...What gives???
  • 659 Answers
Sorry, put you need to post this under automotive and not Air Conditioners. You should get a response there.
Posted on Apr 13, 2009
A/c blowing hot air from front vents, but rear A/c vents are cold in a 2001 Honda odyssey.
It is very likely you have a stuck air temperature control blend door and or the blend door actuator has failed, since the dash must be removed to replace these parts you always do both.
Jul 16, 2016 | 2001 Honda Odyssey
Odyssey air conditioning
HVAC Vent Doors under the dash- need to be diagnosed
One is not operating- to switch the air flow
HVAC Vent Door Motor or Vacuum Motor
which ever type you have
Jul 18, 2013 | 2005 Honda Odyssey
03 honda odyssey no wam airflow through overhead vents but cold blows strong
You mean turn on heat but get Only cold air ?
Is it front heater work and hot?
If so. The heater hose to the rear core is plug. Need to flush it from both direction and make sure is full of coolant (Water).
You should be good to go.
Mai Lor
Feb 25, 2013 | 2003 Honda Odyssey
I have a 2001 Honda Odyssey. I only recently bought this. The rear air con vents only blow out cold air, no matter what the temperature it is set to. The dealer I bought from said this was standard, and...
I've have never heard of a "only cold air system", but hey, nothing surprises me anymore. try replacing the control unit in the front. hopefully that will take care of the problem. If not you need to check your blend valve. (headache depending on location)
Aug 02, 2010 | 2000 Honda Odyssey
I have a 2005 Honda odyssey. When I turn press the rear A/C button, the whole A/C system blows warm air and the a/c doesnt get cold at all....Is this a clogged hose or something??...
Hi i have 06 exl odyssey and i had SAME problem it was like this you turn on front ac and it works and when you turn rear ac then they both blow hot air . What is was a rock hit ac condencer . dealer replaced condencer it was like $700 bucks do not go to dealer just buy condencer for $120 online and it easy to change it and then refill with freon Also after that I put mrs grille on my odyssey . looks good and no problem at all Those condencer are common problem JUST DO NOT GO TO STEALLERSHIP
Apr 13, 2009 | 2005 Honda Odyssey
Rear air conditioner
Hi Moonaw,
Take the vehicle to an expert on AC and ask them to check the gas pressure. If that's ok, then have the evaporator (that's the thing that looks like a small radiator which is the heat exchange unit inside the cabin. also have them check the expansion valve for the rear compartment...The fault must be in that section as the condenser, dryer and compressor are common to both front and rear outputs.
Best regards
Johngee10
Jul 22, 2008 | 2002 Honda Odyssey
2001 Honda Odyssey Ex Air Conditioning Not Cooling
Hi, my best advise is to have your air check for freon leaks ,low freon causes the compresor cluth to stop working ,this can cause the air to blow hot .......
Jul 10, 2008 | 2001 Honda Odyssey
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
