Question about Sony SA-WM500 Subwoofer
No Audio I've had this Sub for sometime. For the last year, it's sat in the corner collecting dust. I was about to buy a new one, but first I want to check and see if this one is fixable. The light on the front still lights, and still changes from red to green when audio is sent to it. I've check inside and all cables are connected. No noticable burns or broken resistors. I've even swapped out speakers, yet nothing. I've tried the mono input, and also the speaker connectors to get signal, yet nothing. Just no audio. Thanks in advance.
  • 1 more comment
  • guitar247 Sep 11, 2007
    Help me out... Where would the three pins be located
  • Beerfrogiii Apr 05, 2008
    I have a SA-WM500 and it seems to still work but cuts off seemingly for no reason at all, until recently now it does'nt push any sound i can't understand why. I made a last attempt recently and for a second or two it worked fine like it had always done. The light always stays on and reacts when the stereo is switched on. Help!!!
  • Anonymous Sep 21, 2008
    Same problem, no audio all of the sudden.
    Problem Solver:
  • 7 Answers
I had a problem with no audio and I recently found the fix. When the sub still worked and you turn it on you hear one relay click and then about 5 seconds later a second relay clicks and the audio comes on. The problem I had lies with that second relay. When you take the case apart there are 4 circuit boards. The big board with the two big blue capacitors is the main board. Well next to the two blue capacitors is a blue relay. That relay had a pin that came un-soldered from the circuit board. I re-soldered that pin and the sub works just like new. If you go here http://www.eserviceinfo.com/downloadsm/20627/sony_sawm500.html you can find a free service manual that has the wiring schematics for the amp. Hope this helps!
Posted on Jul 13, 2008
    Problem Solver:
  • 4 Answers
See if you have three pins... try switching on the system and touching the yellow wire and try if you can hear the woofer give a sound if it doesn't then it is gone
Posted on Sep 11, 2007
  • just take a 1.5 volt battery and touch the two wires from each speaker and it will give a pop noise.. if you hear it the system works
SOURCE:
M-Audio controller. How do I fix a loose sub port?
I just had the same issue. The temporary fix I used worked for 2 years. I just stuck a small paper clip or safety pin in the corner of the port, and then plug the cable in. If those are too big just use something you can use to make the plug fit tight.
It finally stopped worked a couple of weeks ago, so I just bought a new USB port at an electronic store for $1.50 and soldered it on. I had to buy flux which was $3.00.
$5 and an hour of time after squeezing 2 extra years with paper clips. Priceless.
Just make sure you have a cold beer to solder with. Sticking drinks in a freezer wrapped in a wetpaper towel for 15 minutes is like a reverse microwave for beer.
May 12, 2015 | M-Audio Music
Sony CMT-GP5 subwoofer output very quiet
From the description the subwoofer is the problem, since the item is new return it to the place of purchase, this is a manufacture issue.
Aug 13, 2012 | Sony CMT-GP5 CD Shelf System
RE:Yamaha DSP-AX757SE 7.1 A/V receiver Last year I posted my A/V receiver with Royal Mail for an E-bay customer.It arrived to them damaged , so I contacted RM to make a claim .They informed me any E-bay...
It's probably shutting off because it senses a short between the + and - speaker terminals or from + to ground. Only someone with a Mark-I calibrated eyeball focused on it could tell you for sure.
Good luck.
Mar 23, 2011 | Audio Players & Recorders
The heater was serviced and working perfectly about 7-8 years ago and not used since it has just sat in the corner of the garage now when plugged in it sometimes emits masses of white smoke and fumes which...
Im assuming from what your said about "when plugged in" , the heater is electric.
Whether it electric or gas, it simply needs a thorough cleaning, Remember it sat in the "corner of the garage from about 7-8 years ago?" It gathered a lot of dust, dirt, lint and probably a spider or two or even a mouse nest.. It needs to be cleaned inside and out, That should solve your problem. However, do not use water to clean it.
Use a vacuum cleaner that has a hose and crevice tool attachment to accomplish this. Be careful not to break or disturb any wiring. Use canned compressed air with a straw nozzle (like you clean your computer with) to reach into the nooks and crannies to blow away the dust. After you're satisfied that you have done a thorough, spot one job cleaning the heater, reassemble it and give it a try.
This should help to solve your problem, mate.
Feb 12, 2011 | Heating & Cooling
We have a sub zero refrigerator with the freezer on the bottom. The ice maker stopped working and i am wondering if there is a switch that i might have accidently hit to turn it off
No, Sub Zero does not have an icemaker switch to turn it off and on. How old is your unit? Icemakers can last for 3 years and sometimes they can go out after 18 months.
I believe it's your ice maker. We are factory authorized Sub Zero and can get the correct part out to you right away.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We are at your service from 7 AM until 9 PM CST Mon-Sat and look forward to assisting you with this and all your appliance repair issues.
Nov 06, 2009 | Sub-Zero 650 / O Bottom Freezer...
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
Updated maps
There is a new map update available: $299.95
http://www2.panasonic.com/consumer-electronics/shop/Audio/Mobile-Electronics/Strada-Mobile-Navigation/model.CA-MAHD08U_11002_7000000000000005702
Jun 16, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
Sony SA-WM500 Subwoofer Logo
540 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
