Question about Vacuums
I have no suction at all what do I do? - Vacuums
  • 281 Answers
Take all of your filters out then turn it on and see if you have suction.if so the filters are dirty.talke your hose off and blow throughit if you can't the hose is blocked up.also go to the intake hose which is located at the bottom ,it should be kind of clear.it comes up the backside at the bottom.theres a connector it is attached to that is held in be 1 or 2 screws take them out and you should be able to pull it away from the back a little ,take a coat hanger and bend the tip so it is round then work it down into the intake hose and see if you can push the clog out though the bottom .those are the things that will keep it from having suction.try the filters first,then the hose,then the intake hose.good luck
Posted on Apr 13, 2009
MY WRLD VAC BRAVO II DOES NOT HAVE SUCTION
There could be something clogging the suction path.
Nov 30, 2016 | Vacuums
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
How do I switch the vacuum from floor to accessory suction
It automatically switches over when you disconnect the hose from the power nozzle. No suction it getting to the power nozzle, so the suction is only through the attachments. If there is no suction through the hose, check for clogs in the hose and in the tank where the hose plugs in. Also, check the screen at the bottom of the tank. If there is a clog in the hose or tank, then there also will be no suction to the power nozzle.
Remove all clogs and you should get suction.
Dec 19, 2010 | Hoover U5721-900 WindTunnel Upright Vacuum
My DC17 suction hose doesn't have any suction occasionally.
check the seal on the filter is not broken,And check for any blockage at the bottom of the pickup pipe.
Nov 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Suction only works using the hand held mode, there is no suction when try to use on carpet mode,
There must be a clog in either the hose, dirt inland by the brush roll, or bad filters. If you have suction at the end of the hose, then look lower all the way to the brush roll.
Mar 25, 2008 | Vacuums
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
Vacuums Logo
44 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
