Question about IBM ThinkPad T23 2647 Notebook
10 minutes of background processing when coming out of stand-by...What is going on
At the end of the day I'll shut the lid on my laptop. I've got the power settings configured to go in standby mode when the lid is shut. On a recurring, but not consistent, basis my computer will be greatly SLOWED down by some processess running upon taking the thing out of standby (lifting up the lid). This effectively renders my laptop unusable until these invisible gremlins decide it's time to relinquish my computer back to me. And this can take, literally, up to 10 minutes. What's going on in the background, and are there any things I can do to troubleshoot/fix this issue? Running XP Home wireless network to DSL modem Thanks!
  • 317 Answers
Click Start, Run, type msconfig. Click the startup tab. There will be a list of all the programs that start up when your computer starts. You should uncheck everything you don't need. Pretty much everything except antivirus.
Posted on Sep 11, 2007
Window hanging
Wait a few minutes for the non-responding program to start responding again. Be patient and give it some time. This is the easiest way to salvage any work that you did not save before the freeze. If, after waiting, the computer does not unfreeze, move to the next step.
Press and hold the "Ctrl", "Alt" and "Del" buttons in that order. This may unfreeze the computer, or bring up an option to restart, shut down or open the task manager. Open the task manager and note if a program is listed as "not responding." If there is one, click that program title and click "end task." The computer will end that task and break it out of the freeze. If this does not work, open task manager and go to "processes." Look for a process toward the top of the list that is using a large amount of resources. The number next to the process indicates how much of the resources are being allocated for that program. Pick one with the highest number (towards the top of the list) and choose "end process." If your computer still is not unfrozen, move to the next step.
Change the power source of your laptop. For example, if the laptop was plugged in to the wall, remove the plug and allow it to run on battery power. If this does not work, proceed to the next step.
Remove any devices, such as thumb drives or memory cards, that are plugged into the laptop. If this does not unfreeze the computer, move to the next step.
Close the lid of your laptop. Open the lid again. This may snap the computer out of its frozen state and back to the login screen. It may also put the computer into hibernate mode. If this does not work, move to the next step.
Hit the power button. This might bring up a menu asking you if you want to restart or shut down. At this point you will need to restart or shut down the computer. You will most likely lose what you were working on, unless the program has a recovery process to save your work if this situation arises. If the menu does not pop up, hold the power button until the computer shuts down. Wait 30 seconds, then boot the computer up again
Jan 21, 2012 | LG Computers & Internet
Why does my DC17 Animal vacuum keep shutting off?
Hi Emmeline,
I'm sorry to hear you're having difficulties with your DC17. From what you've described, it sounds as if the thermal cutout feature is shutting the machine down to prevent overheating. If you've already tried washing the filter and are still experiencing the issue, I'd encourage you stop using the cleaner and to contact us directly so we can help. You can call us free on 1866MYDYSON, or email We'll look forward to hearing from you.
Kind regards,
Dyson Online Customer Support
Nov 16, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Lid switch shorting somewhere. In this model there is no pin that I can ses. But after removing bezel it flickers but I need the location of the lid switch to check. When opening lid slowly it sometimes...
Probably not a lid switch related problem. In the more modern Toshiba's, the lid-close switch is generally located either above the keyboard area or underneath the front end of the palmrest (towards you), and the lid-close function is activated by a magnet located either above or below the screen. Best way to check if the lid-close function is working properly is to use Toshiba's power management to set the system to go to either stand-by or hibernation upon lid-close - and if the computer goes to stand-by or hibernation when you shut the lid, then that part is functioning properly.
A better, more detailed and precise description of the problem with the screen will probably help in addressing the real problem.
Sep 20, 2011 | Toshiba Satellite P205-S6237 Notebook
Whenever i turn it on it stays for 5minutes then swiych itself off
You obviously have a lot of processes running in the background. Here is a link for the minimum processes you need for win xp:
To see how many processes you have running do this:
1. Place your mouse on the task bar and right click
2. Pick task manager
3. you will see a tab that says processes. Look at the bottom of the page on the left side. It will say Processes : #. Anything over the above links # 10, are programs running in the background that you do not need to have running all the time.
When you install ANY program to your computer, be sure to read every page that comes up when installing. If there is an option/check mark that says something like: "start at windows start up" or "run when windows starts", uncheck it. You do not need to have anything but the operating system files load up when your computer starts. Whatever you download will still be there, it just wont be in the background running taking up memory and resources. When ever you need whatever you downloaded, just go to that program and open it.
With the exception of your virus protection, you should keep these processes as low as possible.
1. On the processes tab as stated above, right click on the processes you don't need, then hit "end process". You should see the number at the bottom go down. Don:t worry, if it is an operating system file that you should not end, it will not let you.
Next time you start your computer, these will all come back UNLESS, you find out what each process goes to, go to that program and find where the option to start at windows start up is and uncheck it.
This should shut down your computer a lot faster and run faster too. Good luck
Mar 14, 2011 | Computers & Internet
Hi, I have a problem with my laptop(2 yrs old). When I turn it on, it shows the microsoft loading screen with the logo and all, but after that the computer screen turns black-- not completely black, but a...
Sounds like a software error. When the screen has been blaxk for a minute or two try hitting control+alt+del and use the task manager to start the process explorer.exe if so then there is a registry or windows error and needs to be repaired.
Oct 23, 2010 | Sony VAIO VGN-C140G/B Notebook
Standy By Going off/Computer shutting down
The presentation power scheme is used when you are giving a briefing using the PC as your slide show. So the presentation power scheme will never shut off the monitor or the hard drive, don't want it to shut down in the middle of a briefing.However, leaving it in that state for long periods of time may cause the CPU to overheat and shut itself down for protection. A better scheme for quick boot up would be Home/Office. Turn monitor off after 20 minutes and "never" for hard disk. This way it will save energy (therefore heat) and you will have a quick boot up. If you are using XP Pro, there is also an option to automatically put it in standby when you close the lid of your monitor. Hope this helps. If you have any questions let me know... Please rate this solution before logging off.
Feb 04, 2009 | HP Computers & Internet
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
No power to the vaio
perhaps you cracked the board? I know I woulda broke it in half. A lil more info would help
Mar 08, 2008 | Computers & Internet
Sony Vaio with Vista
A program that is stopping your computer from being "idle" will stop the computer from going into standby. An antivirus program doing a check in the background, or a backup utility or another background program could do this. Try to terminate the various running applications and see if the problem goes away, then you'll know which program was the offending one.
As for the lid, just doublecheck - go to control panel->power options->advanced and the dropdown that says "When I close the lid of my portable computer" should read "Stand By"
Feb 01, 2008 | Computers & Internet
IBM ThinkPad T23 2647 Notebook Logo
70 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
