Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Transmission fell apart. Looking for blueprint to reassemble.
The transmission to my DeWALT DC920KA Type 1 fell apart. I was wondering if anyone had the blueprint to it to reassemble it.
  • 1 more comment
  • joeyktiet Apr 16, 2009
    Ok. Thank you. I will try to find an old drill and do what you suggested.
  • orangenortha May 05, 2009
    I have the same problem with a different drill Dewalt DW987k-2. I thought I saw a blueprint when I had it repaired before.
  • 154 Answers
The transmissions come as an assembled unit and there are no drawings for the internals. If you can find an old drill that is no good, use it as a guide.
Hope this helps
Posted on Apr 14, 2009
I have a DeWalt DC925 type 1 hammer drill,took it apart to repair switch and clean. Four pin bearings fell out,I don't see them on a parts diagram,where do they go ?
You will find them in the transmission, remove the metal cover and they will be located just under it - sounds like it is either the gear posts or the clutch cams on the nose side of the transmission DeWALT DC925 Type 1 Hammer Drill Parts
Mar 23, 2015 | Dewalt DC925 Cordless Drill
Wher do pin bearings go into the transmission of a dewalt 18v cordless drill
if its like my DC925,you have to remove front of trans. toward chuck! its a plastic piece with a s.s. flat spring washer. if washer falls out install from bottom of plastic when removed from trans. bearings stand in gear grooves. make sure if nut falls out match 1 with 1!
Oct 11, 2013 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
DeWalt dc728ka transmission assembly help
Go to e replacement parts and put your model number in and this will get you a parts break down
Jul 25, 2013 | Dewalt DC728KA 14.4V 1/2" (13mm) Cordless...
Have an older dewalt impact driver that needs a new trigger. where can I get one?
You're looking for part number 152274-25. If you type "dewalt 152274" into your search engine, several dealers selling this switch will come up.
Oct 25, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I need blueprints, schematics for the various Dewalt18 volt drills/hammerdrills
You won't get those. You might get the schematics if you were a certified dewalt repair depot but the drawings are not released to anyone.
Oct 10, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have 3 of these and all of them have a problem after a while that they slip the clutch even when it is selected to the drill position, can the clutch be adjusted?
I just took mine apart and it appears that you have to replace the entire transmission. It is an easy job and the part is about $34 much cheaper than a new drill. Really, it is one third the price of a battery. Just take the 4 screws out that hold the metal case to the plastic clamshells, slide the front of the drill off, pull the transmission out of the rear of the drill put the plastic piece with the gear indicator on the new trans, if needed, slide the new trans into place, spin the motor if needed to get the output to line up with the planetary gears, slide the front of the drill back into place, rotate the chuck to align the shaft  with the transmission output, put the 4 screws back in, enjoy.
Might want to replace the brushes while you are in there as well. I am going to consider this the dewalt version of an oil change
Dec 29, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt dc 980,when i spin the torque dial from 1 to 25 nothing changes
You need to get a new transmission. There is a spring and pin that get worn in the transmission. Dewalt doesn't sell just the spring and pin. You will have to get the whole transmission. The part number for the transmission is 397892-05 for the dc980. To change it you undo the screws holding the housing together. (Make sure battery is removed first.) Undo 4 screws holding front assy on and remove. Undo back cap screws and remove. Pull the right side cover off and leave drill seated on bench. Do not pull entire assy out of left handle. slightly angle the motor transmission assy and slide transmission off. Replace with new transmission. (Lining up teeth is not easy but keep at it until you get it.) Replace motor and transmission assy and reassemble in the reverse order above.
Sep 28, 2009 | Dewalt 18 Volt Compact Drill Kit
Fell apart!!
the transmission comes in assy. all u can do is to match the gear & test every small installed. if it's dw997 see www.erplacementparts.com for your guide how to re-assemble.
if dw988 trans diagram see similarity on how to put it back.
Aug 16, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt Drill
if the drill is slipping in speed 3 & drill mode. it needs new transmission assy. see www.toolpartsdirect.com , www.ereplacementparts.com for pricing for the the parts.
Jul 27, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Transmission problem
front of the trans had a pin the spring is inside. if theres no tension maybe missing spring or the large out crown gear are worn. you can get the trans in assy,
May 29, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
646 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
