Question about Edimax BR-6104P Router
New internet provider
We got a new internet provider but the router wont let us switch over to it so we can run 2 computers
  • 1 more comment
  • erowyn1615 Apr 14, 2009
    the modem is an arris the router is an edimax
    the isp is comcast cable internet
  • Eustache Duverna
    Eustache Duverna May 11, 2010
    what is your ISP name or what is the name of your modem and router that you are using?
    Problem Solver:
  • 7 Answers
Can you get one computer to surf directly from the modem? if yes, connect the router wan port to the modem
press the reset button on the modem and after resetting the modem, try to get an IP from your router
if it doesn't work, get the MAC address from comcast device and clone it to your router WAN MAC (hope this option is available on the router)
Posted on Apr 14, 2009
Last january my d-link WBR-2310 still working fine but now i wanna use it, it wont connect in the net?
Try power cycling the router.
Disconnect the router from all computers. Power off the router. Power on the router. Reconnect the router to all computers. Check the Internet connectivity.
Mar 01, 2011 | Computers & Internet
Internet wont work thru my Linksys BEFSR41 Cable/DSL Router W/4 Port Switch.....can i fix it or do i need a new one?
hi there, you need to configure the router first to connect over the internet.
checked if everything is properly connected, modem-router to the computer, checked the lights on the router and the modem as well if it is properly lit up.
if your ISP(Internet Provider) is cable then you need to clone the mac address of the computer, if you are running DSL, you need to input the username and password of your account from your ISP.
Accessing the router setup screen, open IE and type on the address bar 192.168.1.1 then nothing for username and password is admin.
on the setup screen you will see there Internet connection type, by default it is automatic configuration if you have cable connection as your Internet then leave it that way and look for mac address clone sub tab.
if you are running dsl for the Internet connection type you need to put PPPoE and input there your username and password from your ISP. then in everything you do you need to save the settings there.
tell me if it
Jun 26, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
DHCP problem and router connection
  • access 198.162.0.1 router's configuration page and set the settings IP addressing to DHCP or auto assigning the IP addresses and the DNS
  • set the router mac address to the middle option set to computer mac address
  • and make sure all the computers connected to the router and the switch is set to automatically detect the IP address and the DNS is all set to auto detect...
  • how to access XP...goto to control panel and select network connections (for vista network and sharing center, manage network connections) and right click on the LAN, select properties select tcp/ip and click properties. and selct automatically assigns IP address and DNS.
Jun 07, 2008 | NetGear FS608 Networking Switch
G router wont work through vista or satellite dish
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 01, 2008 | Belkin (F5D7230-4) Router (587009)
Internet wont work
hello!
May 08, 2008 | D-Link AirPlus DI-524 Wireless Router
Stoped working
Check to see if you can see other computers within the network. If you can then its not the router that is the problem but could be your isp.
First thing is to do a hard reset. Use a small toothpick to press the button on the back of the router. Be equipped with your username and log on of your ISP provider then go thorugh the wizard of setting your router up again. IF this doesnt solve your problem then follow the steps below.
1. go to run cmd then ping 127.1.1.1 this will test if ur tcp/ip is working. If it is then go to step 2.
2. ipconfig /all this will help you find your ip address that has been assigned your computer.
3. ping the router probably 192.168.1.1 or 192.168.0.1 this will show that u can reach your router.
If all above tests work then its more than likely your ISP so give them a call.
Jan 14, 2008 | Zyxel Prestige 660HW Wireless Router...
Wireless router WRT54G version 2
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
let me no know in case if you have any problems ...
Nov 18, 2007 | Computers & Internet
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Internet connection problems using the BEFW11S4
If you are having problems connecting to the Internet, follow the following steps: 1. Internet service: Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. This will narrow the issue down to either the service, or the router. 2. Network cables: Verify that the network cables that connect the network together are plugged into the current ports as they should (modem into the WAN/Internet port, computers into 1, 2, 3, or 4). Also try to change some or all of the network cables that attach to devices coming from the BEFW11S4. You may have bad cables. 3. Router configuration: Your router may not be configured to use your Internet service properly. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. Note: this program must be executed on the main computer when plugged directly into the providers modem unit and able to get on the Internet 4. Manual configuration: If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online, visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 5. Router firmware: Upgrade your router to the latest firmware version. Please go to http://www.linksys.com/download to download the latest version of firmware for your product. After the upgrade, be sure to reset the router, by holding in the router?s reset button for 30 seconds and reconfiguring it for use with your service (Step 3 or Step 4). 6. Malfunctioning equipment: You may have a faulty network adapter, or a bad router. Please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Configuring the BEFW11S4 for the first time
To configure your router to share your Internet service, please follow the steps below: 1. Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. 2. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. 3. If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online (Step 1), visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 4. Once one computer is able to access the Internet through the router, the router will then be configured. Other machines can now connect to the router without re-configuring it a second time. 5. If you are still having difficulties setting up your router, please contact Linksys Technical Support so that we may further assist you.
Edimax BR-6104P Router Logo
122 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
