Question about ASUS P4S8X Motherboard
Vga I purchased a asus p4s8x mb I've installed everything but when i turn on the system the monitor displays No vga signal. I've checked the conections and everything is ok. Can anyone tell me what the problem. The grafic card worked on the same mb but in a diferent case and now that i've changed the case is not working any more. The red led wich indicates if the grafic card is not good is off. so....????
  • msrdanny Sep 11, 2007
    the mb has only one agp slot so...
    I was thinking that maybe i have to clear the cmos or god knows some jumpers
  • Anonymous Apr 27, 2009
    no vga coming
  • 37 Answers
Try to clean contacts of the graphic card and the mems with a pencil eraser,reseat it again and check if it is properly inserted or seated in the slot...
Posted on Sep 11, 2007
  • 4 Answers
I would try switching slots on the MB. I'd hate to think a new MB has bad slots, but I've seen it happen. You might also want to try the card in another computer that you know is working. If it works there, then you've got an MB problem, if it doesn't then I'd say the video is bad. Bea
  • Bea Hall Sep 11, 2007
    Clearing the BIOS might help, pull the battery out and leave it for a while if you can't get a display to see what you're doing. I know I've run into boards that had the AGP slot disabled. Go figure!
My Dell E173fp monitor display doesn't work with my macbook
The fine print says it should work. Real life might be different. Do you have a genius bar, found at Apple stores, anywhere close? If so, make an appointment and let them make the connection for you. The genius bar is a free service and I've never found anything that they haven't been able to fix...and fix it quickly...if it's fixable.
Apr 17, 2017 | Dell E173FP 17" LCD Monitor
No vga signal
Either your graphics card is going bad or your monitor is going bad or your connection is lose. Just check your connection and make sure it is tight.
Jan 11, 2012 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
A bios nao reconhecer o son
Verificá-lo durante a inicialização do BIOS http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=270&SLanguage=en-us
BIOS mais recente Baixe para P4S8X-X de
http://www.roxysoft.com/drivers/ASUS-P4S8X-MX-Bios-v-0502-download-driver/
Siga as instruções e instalar:
http://www.asus.com/999/html/events/mb/ezflash.htm
During bootup check you bios http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=270&SLanguage=en-us
Download latest bios for P4S8x-X from
Follow instructions and install:
Sep 15, 2009 | ASUS P4S8X-MX Motherboard
This is a new install, no vga out
You Can Try By Cleaning Out The Memories And Checking The Processor Is Placed Right In The Socket
Dec 25, 2008 | ASUS P5P800-MX Motherboard
DVD display problem
Try " VLC Player " it plays 95% of music and video files
Oct 12, 2008 | ASUS P4S8X-X Motherboard
Installed GeForce 8500 GT PCI-E video card and pc will not turn on
If your mboard has a builtin video card you should configure that b4 u can use that add on card.
1. connect the add on card.
2. connect the monitor to the built in VGA.
3. start system and press "F2 or Delete" to go to bios setup.
4. on bios setup " refer to the manual on installing addon PCI express card".
you find it here: http://support.asus.com/download/download.aspx?SLanguage=en-us.
or enlosed in the board.
After configuring your system restart and unplug in the wall outlet and then connect the monitor in the add on card.
Hope you find in order.
Jan 18, 2008 | ASUS P5GD1-VM Motherboard
Monitor Problem
Well assuming you used the same video cable when you tested the monitor on the Asus PC you?re left with: - Physical problem with the Asus video card. - Asus video card configuration problem. - BIOS configuration problem - Possibly a problem with the DVI/VGA adaptor depending on the answer below. A couple of questions about the Asus before we start: - I?m not sure I understand how the DVI/VGA converter figures into this. Is your cable coming off the monitor DVI thus you need it to plug into the Asus VGA connector? If yes who is the manufacturer of the device and what model do you have? - Has the Asus worked in the past with another monitor or is this new? - What is its history/configuration?
Mar 11, 2007 | ASUS T2-AH1 Barebone
Asus P4S8X-X - Pentium 4 - 2.4 GHz
I would try another Power Supply Unit.. are you sure it's the PC and not the monitor thats faulty? You could check this by connecting another monitor,and see if it does the same...
Dec 19, 2006 | ASUS P4S8X Motherboard
ASUS P4S8X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
