Question about Samsung CLX-3170FN All-In-One Laser Printer
How do I stop the printer from printing in color?
When I print using 'black' the printer still uses color toner. How do I stop the printer from printing in color?
In the print dialog box, click properties, then 'graphic', and choose greyscale.
You can also set this as a default.
Posted on Nov 03, 2009
  • 74 Answers
Try connecting the printer to a different computer. It might just be one opne particular machine. If so then just uninstall the printer softwae and reinstall.
Posted on Apr 13, 2009
I can't print in black and white though I have black toner
Hi, when the printer finished warming up. it will prompt Toner Empty - Stop, use the arrow key changed to continue and you can start printing. remember you must always do that whenever this msg appears.
Oct 09, 2013 | Samsung CLX-3175FN Color Laser All-in-One...
Printing only black in TallyGenicom 8108N
You can change the colour setting in the printer driver to Black Only, this means you will only print Black and White using only the black toner.
To make this change on Windows XP;
Open the Printers and Faxes Folder.
Right Click on the printer driver for the 8008.
Select Printing Preferences.
Click on the Color/Print Quality Tab.
In the Color Mode section select the B&W radio button.
Click on the APPLY button
This should change the pritner driver to print only black and white.
Mar 23, 2010 | TallyGenicom 8008 Laser Printer
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
Do i have to have toner for all colors if I just want to print black and white?
It is like he says. My 9420cn uses all the colos even if the machine just prints out received faxes. Its really annoing and costs too much.
So does anyone know a solution how to stop it from using all colors to print black?
Sep 21, 2009 | Brother MFC-9420CN All-In-One Laser...
Konika Minolta 2430 DL won't let me print
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Jun 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Color toner used up even though I selected grayscale
Selecting grayscale only will also make use of your color. when u select grayscale, look under the print options and select black cartridge only and for more economic printing, use fast draft or draft printing.
Jun 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Still using color toner when printing in black
Check the black toner cartridge. Most printers that use multiple cartridges will use the black cartridge as long as it has toner in it but will then start using the color toner to do the black/grayscale when the black cartridge is empty.
-Graye-
Nov 21, 2008 | HP LaserJet 2550L Printer
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Printer won't print black
Gently roll or shake your black toner cart.
when you do not use the printer on a daily/weekly basis, the toner dust compacts in the bottom of the holding area of the toner cart, and can sometimes cause these problems.
Jul 29, 2008 | HP LaserJet 4200 Printer
Samsung CLX-3170FN All-In-One Laser Printer Logo
179 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
