I have the same camera, and found out that the VRO file is just MPEG2. So copy the VRO file onto your computer from your disc. Once its on your harddrive, you can right click on it and go to properties. Re-name your file from VRO to MPG, making sure that you still have the original VRO file in case you need it for other programs. Once I change it to MPG file name, I can use media player to play it and I have a DVD movie maker where i can edit and record to DVD.
BUY THE BATTERY CHARGER ..........
AC ADAPTER / BATTERY CHARGER DZ-ACS3
I have the same camera as you - i wish i could figure out how to charge the battery - as i dont see a connection anywhere on the camera to charge the battery up... can you help with this>
Hi Tell me the extension of the file you try to play.
I apologize for the delay in responding, and I appreciate your assistance, I simply have been unable to devote any further time or enegy to this particular problem. I will however, determine the exact extension soon, and having done so, I will definitely relay that information on to you, so that you may better assist me with my problem. Thank you.
I also have this issue except i'm using Windows Vista Business and XP Pro, i've finalized a dvd-rw (VR Mode) disc but when i place it in my PC it does not play it but i can browse the files on the disc. The directory structure is like this:
DVD root
-DVD_RTAV (folder)
--VR_mangr.bup
--VR_mangr.ifo
--VR_Movie.vro
-RTR_EXTN (folder)
--rx.dat
--VR_Stdum.000
.sys-reserved-rw-bitmap.grow
If i place the disc back in the camera i can play back these files but no longer have an option to finalize the disc.
Thanks,
