Question about Samsung RGSF5330DT Gas Kitchen Range
FTQ386LWUX elcetric range oven door needs adjustment > tight at bottom loose at top not square with range and does not line up properly with bootm warming drawer.
FTQ386LWUX range door needs to be adjusted > bottom tight and does not line up with bottom warming drawer
Coldcut
  • 1554 Answers
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
johnychel
  • 796 Answers
SOURCE: warming drawer
Its either a bad electronic control board (http://www.repairclinic.com/referral.asp?R=1265&N=244804),
or a bad bake igniter (http://www.repairclinic.com/referral.asp?R=1265&N=1990).
Posted on Jul 08, 2008
57 varieties
  • 1653 Answers
SOURCE: Husband removed oven door when fully open instead
Try removing and refitting it a few times otherwise you will probably have to get new door latching mechanisms. You may just be lucky that they have been dislodged but they are most likely to have been broken. The clicking is the door interlock mechanism trying to lock and unless it succeeds the oven will not work.
Posted on Oct 24, 2009
iwillfixforu
  • 619 Answers
SOURCE: Whirlpool GR450LXLQO range while changing oven
You will have to replace the light socket. Part number is 3150505 at approx. 30.00. Hope this helps
Posted on Feb 03, 2010
oldTech2332
  • 2341 Answers
SOURCE: "F3E2 warming drawer sensor" has
What you need to do is find the wiring diagram for that oven,typically its in a envelope inside one of the side panels with the warming drawer pulled out and look and see where the wires for the warming drawer sensor goes onto the control board and measure their at that plug on the board for between 1060-1100 ohms of resistiance ,if 1060-1100 ohms is their on that plug at the board the board is going to be the problem..if their it is much higher or lower the problem is going in the wiring from the sensor to the board..this is assuming the new sensor measures bewteen 1060-1100 ohms as the old one did when checking it??
Posted on Aug 28, 2011
The top of the oven door is turning brow after using the self clean oven . This is the secound time ?
door nor sealing tight --check door seal at top and replace if damage--check lock may need adjustment
Sep 21, 2016 | Kitchen Ranges
Oven door wont close properly chef gbc5266wng
Wow Must be a very old oven. The closes model number I can get is GBC26CK. But most hinges have no adjustment to them. They just need to be changed out.
http://www.on-timeapplianceplano.com
Jul 23, 2012 | Kitchen Ranges
Decor double oven - Door adjustment
Unfortunately yhe door hinges are non adjustable.
The only solution is to replace the hinges as a pair.
Hope this helps.
Dec 15, 2009 | DCS WOS-230 Oven
Lofra five burner gas cooker, oven door not closing properly,
It sounds like you need to check the fixing screws of the oven,failing this replace the hinges.
I hope this helps.
Jul 07, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Dacor ECS130 Epicure Electric Single Oven
Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Oct 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
KDRP407HSS oven door adjustment
I found a solution. Remove door (very simple procedure listed in Use and Care Guide). Make a shim and attach it to the end of the hinge arm (the part of the hinge protruding from the door that goes into the slot in the frame). I used metal shears and a coffee can and made a metal strip that I wrapped around the arm 3-4 times. Reinstall door and it should be tight at the top. (Unfortunately I suspect this fix will be temporary until the ill-designed hinge mechanism starts bending again.)
Nov 12, 2007 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
May 14, 2006 | KitchenAid KEMC377K Convection / Microwave...
Samsung RGSF5330DT Gas Kitchen Range Logo
138 people viewed this question
Top Samsung Kitchen Ranges Experts
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
