Question about HP DeskJet 5550 InkJet Printer
Heavier weight resume paper was apparently misaligned and started to jam printer. I pulled paper out and now carrier is stuck in middle, the power button and paper jam button both blinking. I tried unplugging, restarting. I even tried to turn off and get sound effect like there is a problem and won't stay off while I am on computer. should I uninstall and reinstall? I had just installed a new black cartridge and one of the error messages I got said the cartridge wasn't installed properly or was low on ink. None of the error messages I get are making sense. HELP please..I have 2 brand new tricolor cartridges and don't want to have to buy a new printer (can't afford it!)
  • amyschomaker Apr 13, 2009
    The paper did not rip, so I know there isn't particles under the print head
  • 21 Answers
Although you got the paper out of the printer, there may still be some small pieces jammed under the print head. You may have to manually move the print head to get at the small pieces. You need to make sure the printer is unplugged before you try this. Once the carriage seems to move freely plug the printer back in, it should move to the right where it will come to rest. You should go through the change ink process, but just take out the one that's already in there and then put it back in again. Also run the head cleaning, alignment, and print test utility before attempting to print. If you still are having problems there may still be pieces of paper stuck in the print head. In that case repeat the process again. I hope this helps you.
Have a great day!
Carol.
Posted on Apr 13, 2009
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
Paper will not feed. There are no apparent jams and I have removed paper and reloaded several times. The printer will pull the paper down misaligned and jam.
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Paper twists and jams every time i use it
You might try heavier weight paper.
Also, be sure to fan the paper prior to seating it.
It's also possible that a previous jam may not have been completely cleared and there is stuck paper jamming new paper.
Oct 13, 2009 | Lexmark Office Equipment & Supplies
Canon MultiPASS MP730 All-In-One InkJet Printer Paper jam
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
May 10, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
Canon mp730
Feb 02, 2009 | Canon SmartBase MP730 All-In-One InkJet...
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
Jan 29, 2009 | Office Equipment & Supplies
Canon Pixma iP1500 printer indicates paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 22, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Printer
Aug 08, 2008 | Canon PIXMA MP510 All-In-One InkJet...
HP DeskJet 5550 InkJet Printer Logo
101 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
