Question about Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,
How do you know if the rapid heater for jacuzzi tub is bad?
We have had our jacuzzi tub, model number DC25 for a little over a year.. Long enough now fot the warrenty to be over with. We have used the tub and the heater was working fine, kept the water warm. We notices now that the indicator light on the front of it is not on. We have taken the heater off and looked inside to see if there is any visable reason for the heater to not be lighting up. No visible reason seen. Do you know any suggestions for testing the heaters internal components? Do you know where I can find a schematic on the heater? We did notice that the reset button feels like it is maybee broken. It will not push in at all. I dont know if it just wont because its not tripped. With regular reset buttons that I have seen in other electrical components they can be pushed in and out even if its not tripped, but it just will feel easy. When they are tripped there is a little effert to push them in (like clicking the buttons on a keyboard). Not sure if we need to buy a new heater or if its just something simple internaly. We dont want to buy a new heater if its just the reset button or some other component that can be replaced cheaper.
  • 74 Answers
All heaters have a thermostat (or multiple) and heating elements.
Start by removing the elements and seeing if they are burnt through.  If so, replace.
If they look fine then replace the thermostat(s).
Both are relatively easy and cheap to perform.
Remember to turn off the power and water to the heater and drain the unit completely before doing any servicing.
Posted on Apr 13, 2009
Jacuzzi tub will only turn off if tub is empty
This sounds like maybe you have a bad circuit on the control that turns the pump on/off.
Get the model number off the control box under the tub and let me know what it is and we can solve that issue for you.
Rod
US Parts Center
888-521-6183
May 03, 2014 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi j325 my tub is about 7 years old, I noticed the tub had no power so I checked the breaker in circuit panel and it was tripped, I reset the breaker and by the time I get back to the tub it trips...
There are several things that can cause this problem. The first is you just have a bad breaker, next is your heater unit is bad, lastly the pump motor could be bad. There is also the possibility that the motherboard is bad again.
Sep 11, 2013 | Electrical Supplies
Hello, a few months ago I installed a jacuzzi tub with a Rapid Heat heater. I'd like to clean the tub either by the bleach/detergent method or the granule cleaning packet method. My question is should I...
Any recommended (see the tub instructions) cleaning product should be fine in the heater -- and the higher temperature of the "cleaning solution" should enhance the process. Just be sure to flush the tub's entire system with clean water before you bathe in it again!
Dec 01, 2017 | Jacuzzi S750000 Black RapidHeat In Line...
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
Jan 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
No heat with Rapid Heat U395000 Jacuzzi jetted tub
can be thermal overloadswich somewhere. it switches of when there is no or not enough water in heatingpipe
Feb 07, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Black soot in my jacuzzi tub
sounds like the rubber seals are going bad, does it recomend to run cascade thru the jets? this might be harmful to the gaskets and the pump, you maight want to disconnect the hose and flush out the tubes going around the tub, but I would call jacuzzi and ask them if this is good to run thru there, thye might be able to help you with the gaskets, questions over the phone do not cost you, call them, ask for repairs section good luck
Feb 27, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Rapid Heater for Jacuzzi
The light is supposed to be on when the tub is full of water and the pump comes on. Make sure the heater is plugged into a seperate breaker, it cannot be on the same line as the pump.
Look on the heater for a label. If your heater is installed on the discharge side of the pump it should say "pressure heater" on it. If it is installed in front of the pump it should say "Vacuum Heater" on it.
Once installed, fill the tub with water and turn the pump on. If it is installed in the correct position the light will come on when the pump turns on.
Feb 22, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Rapid Heat Bath Heater - indicator light on but not heating water
Bathtub heaters will not produce the heat out a the jets like you would feel coming out of a return jet in a swimming pool.
Bathtub heaters will ONLY maintain whatever temperature water you put in there. they only heat 1-2 degrees an hour. that is for a 1500 watt heater. Many heaters today are only 650 watt or perhaps 700 watt.
Feb 21, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools, Logo
931 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
